My radiator and fan, pics inside
1 Post
I had a smaller fan before but now this fan is the SPAL fan. I can`t center it because the downpipe passes in front of the rad.
The section of the fan that is not on the rad, I`m planning to put a piece of plastic (like the crazy carpet plastic) so nothng goes flying in to the blades.
So what do you guys think? Is this ok? Any other suggestions?
Re: My radiator and fan, pics inside
If you buy a pusher fan then it's already wired to rotate the correct direction... if you reverse wire a puller it will push but not as well as a designed pusher as the fan blades are not optimized. but it works...
Also pusher fans are not as affective or efficient... but they will probobly work fine.
If you can pull the fan back 1/4 to 1/2" it would work fine with a properly made shroud. That would be much better than a pusher setup.
Mine is right at the edge of my radiator but the same idea would apply, just fill in where you were going to put the plastic.
why cant u mount it on the other side and reverse polarities to push or pull and thats solves ur problem and i know it will fit cuz i have it that way
Hex213
10
02-16-2013 02:20 PM
AgentJam
07-01-2005 05:23 AM
