DSM injector seals
Old Mar 22, 2010 | 08:15 AM
delinquent's Avatar
Default DSM injector seals
looking to run some DSM injectors (late model turbo 450cc I believe) in a B17A1.
I basically just need to know if these o-rings are gonna fit these injectors in my fuel rail.
here is the link:
http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
thank you very much!
also I have a warlbro 255lph fuel pump I will be running with these injectors.
Old Mar 22, 2010 | 08:27 AM
rexload's Avatar
Default Re: DSM injector seals
Ive installed DSM injectors and they are a direct fit into the OEM honda seals
Old Mar 22, 2010 | 08:54 AM
90Rexx's Avatar
wrong... the OEM seals need to be dremelled out a bit to fit the dsm injectors.
Old Mar 22, 2010 | 09:23 AM
delinquent's Avatar
so.... i could use dsm seals on dsm injectors in the honda fuel rail? I was just wanting to know if the dsm o-rings would seal in a honda fuel rail?
Old Mar 22, 2010 | 09:40 AM
dpetro1's Avatar
the seals you linked are not for the fuel rail. they are for the intake manifold and from what ive seen you would need to dremel them out a bit to fit. i would just get a honda gasket set. there is a top o-ring for the fuel rail as well as cushions then the IM seals that may need to be opened up a bit
you pictured #2 which seals the IM then you also need #3 and #18, most parts stores sell them as a kit. there also may be a hard plastic spacer in the IM, that can be removed
Old Mar 22, 2010 | 09:51 AM
rexload's Avatar
What do you mean "WRONG"??? I said I personally installed DSM injectors on Honda fuel rails and they are a direct fit. How can it be wrong when I have first hand experience.
Old Mar 22, 2010 | 10:04 AM
delinquent's Avatar
ok well I confused myself then. I need #2 seals for sure (referencing dpetro1's image).
Old Mar 22, 2010 | 10:40 AM
esedulerp5tenin's Avatar
wrong. i dremeled the seals out (cuz i heard this too) and they leaked.
so i bought 4 more new seals from honda, lubed 'em up, GENTLY used some leverage to pry the fuel rail/injectors down to seat properly, and haven't had a single leak!
Old Mar 22, 2010 | 11:17 AM
dpetro1's Avatar
get honda seals, test fit, then dremel if needed.
martial
Feb 21, 2010 08:34 AM
K i l l a B e e.
Dec 19, 2008 02:28 PM
ganmar1
Mar 26, 2008 08:41 PM
