B16 turbo bogging need help!!!!!!
Old Mar 22, 2010 | 01:39 PM
beamer's Avatar
Default B16 turbo bogging need help!!!!!!
Alright well I got a b16 fully built thy has been running fine until lastnight. We ran it lastnight and it died! Vacume usually runs at-16 on idle and now it's at -6... That's not right. It's bogging bad and can barely stay alive..
We chaned out the spark plugs cause one if them blew.... I checked the cap and rotor and it seems fi e but the spark is sti not that great. The vacume lines have been checked and everything seems fine. It's not on safe mode anymore but why is it still running like that! I need hp ASAP!
Old Mar 22, 2010 | 06:00 PM
beamer's Avatar
Default Re: B16 turbo bogging need help!!!!!!
Anyone? I would aappreciate the input.
Old Mar 22, 2010 | 06:38 PM
vwbased's Avatar
have a nice day
Old Mar 22, 2010 | 07:32 PM
joe7ep3's Avatar
Was wondering if perhaps a blown head gasket would be a possibility? It's my EK with the problem and thought it could be that aswell
Old Mar 22, 2010 | 09:32 PM
joe7ep3's Avatar
Car has forged internals and custom sleeves 8.5:1 compression and is tuned to 19psi... Any ideas what mightve happened?...
Old Mar 22, 2010 | 10:05 PM
beamer's Avatar
Originally Posted by vwbased
1. Possibly hurt the pistons. Broke ring lands, etc.
2. Skipped a tooth on the timing belt and retarded cams about 20 degrees.
Do a compression test and check the alignment of the cam timing marks.
Thanks man we'll check that asap! I sure hope it ain't the pistons but I was reading up that it could be but a compressions test should do it...
Old Mar 25, 2010 | 09:49 PM
joe7ep3's Avatar
Broken valve...
Old Mar 25, 2010 | 10:33 PM
lyncoors's Avatar
maybe a boost/vacuum leak
Old Mar 26, 2010 | 09:42 AM
joe7ep3's Avatar
thats what i thought too, but i did a compression test and a piston was dead, so i figured it was something in the valvetrain, so me and a buddy took apart the head, and its a broken valve...
Old Mar 27, 2010 | 12:13 PM
beamer's Avatar
Ended up being a broken valve!!! Does anyone know where an if we can buy single valves since we don't want to replace the whole valvetrain?
Old Mar 27, 2010 | 01:06 PM
joe7ep3's Avatar
word.. i need just one crower exhaust valve!!!!
Fresh'86
Mar 30, 2010 09:38 PM
JDMmadness
Feb 15, 2010 05:09 PM
hondabro4321
May 4, 2008 07:22 PM
MaxxdoutSRT4_EK9
Jun 28, 2004 11:29 PM
ludelvr
Aug 20, 2003 11:28 AM
