My F2B CRX long term project
Re: My F2B CRX long term project
Thanks man whp goals with the stock long block other than head studs and a bisi cam will be around 350-400 while im building another block and head for faze 2 goal around 700-750
I will more than likely running a gt4088r cuz I can get one at a good deal. If not a billit 67mm journal precsion turbo so it should not be hard to achieve my goals
Plus it will be a little unique since not many people are running it as well as no competitive turbo car that I know off
Nice project you working on. I am contemplating doing this myself once I get tired of my d16 build. What compression are you considering on the built motor? I was thinking of doing a 10:0 compression f22 build on boost...I see a quite a few people are starting to run higher compressions on their boosted setups with great results. I also have a ed chassis so keep us updated on your build.
thanks ya i was planning around that same compression or a little higher also
Nice project. Im also doing an F2B crx, except it will be NA, and not a competition car. Which trans are you going to be using?
Ive got a gsr hydro tranny that im planning to run a mfactory LSD in it.
Finished mocking up front end and mounted it on
Started cutting out the bumper to start mocking up intercooler and turbo manifold
supercivicstack
20
07-11-2009 07:11 AM
Fireman.142
03-24-2009 08:03 AM
