timing boosted b20...HELP PLEASE
Old Mar 24, 2010 | 07:24 PM
hondapimp125's Avatar
Default timing boosted b20...HELP PLEASE
hi guys,
so heres the deal i just got my b20 with built ls head back together and went to time it today heres what happened...
-aligned all my marks
-using brand new honda crv timing belt
-using semi new belt tensioner
-get the belt on, turn it over by hand and the belt jumps on the crankshaft pulley every time..
I can't figure out why it keeps jumping off the pulley so anyone who can help its very much appreciated!
** I'm also running a 19tooth water pump which is the ls water pump i believe**
Old Mar 24, 2010 | 07:28 PM
bluejcivic's Avatar
Default Re: timing boosted b20...HELP PLEASE
did you try pushing the tensioner up to take up the slack and tighten it.
Old Mar 24, 2010 | 07:50 PM
yes i already tried that mutiple times
Old Mar 24, 2010 | 09:15 PM
bluejcivic's Avatar
double check the part number on that belt. maybe they gave you the wrong one.
Old Mar 24, 2010 | 09:34 PM
V-SPEC 1's Avatar
pictures would help too.
Old Mar 25, 2010 | 06:59 AM
yeah very doubtful that they gave me the wrong one, but a possibility i guess.
yes i'll post some pics tonight..
one guy told me i need a gsr timing belt??
Old Mar 25, 2010 | 07:10 AM
sleepencivic's Avatar
when you tensioned the belt did you turn motor 3 teeth counter clock wise then tighten the tensioner? This is what sets the tension on the belt!
Old Mar 25, 2010 | 07:27 AM
no I didnt do that!
i was unaware that was neccesary.
I'll try that tonight when i get home an leave an update
Old Mar 25, 2010 | 11:54 AM
thank you so much bro!!!!
timing is perfect now
Old Mar 27, 2010 | 01:11 PM
no problem...glad to help. do this on all b series and d series motors and you will be golden. still check the timing by rotating the engine 2 or 3 revolutions and check again.
Old Mar 27, 2010 | 07:19 PM
teaks92hb's Avatar
good info sleep! I'll remember that also, may explain why my LS ran like poop!!
DENNO
Jun 3, 2013 12:46 AM
VegaS10
May 20, 2013 12:05 PM
hondapimp125
Mar 24, 2010 06:21 PM
---NON-VTEC---
Mar 30, 2008 11:54 PM
eddiecut
Jun 16, 2003 12:10 PM
