what all comes with a JRSC for a b16a
thinking about buying a JRSC from someone and i need to know what all should come with the supercharger be4 i get it
Re: what all comes with a JRSC for a b16a
Search http://lmgtfy.com/?q=www.supercharger.com it owns you
Christ some people are lazy. If you followed the 1st page that came up in the search that was provided for you, you would have found a website for the manufacturer of the supercharger kit you are planning on buying, and on that website, you would have found this: http://www.supercharger.com/graphics/BOMS/989-250.pdf a full listing of all the parts in a B16A supercharger kit for 99-00 Civic Si.
i used the link and went to the parts list..tryed to download it but like 40 new tabs poped up on my screen and i couldnt view it does it every time idk wtf but could one of you get the list and post it for me that would be great thanks
Hope this helps. Just make sure you get everything for the JRSC that is coming off his car.
Bill of Materials
99-00 Civic SI (989-250)
988-043 S/C SUPPORT BRACKET KIT 1
051-074 WASHER FLAT M8 1
051-135 BOLT FLNG M8X40X1.25 FULL THRD 1
051-186 NUT, HEX FLANGE M8-1.25 1
051-495 SPACER 21/64 X 1 X 0.5 1
051-505 BOLT FLANGED M8X25X1.25 12 AF 1
051-421 BRKT ENGINE TO S/C BRACE 1
988-100 TENS,ASSY,UPPER 1
051-081 WASHER FLAT M10 1
051-093 SPACER .450 1
051-102 UPPER STRUT BELT DRIVE 1
051-103 ADJ PLATE, UPPER BELT 1
051-104 PIVOT NUT UPPER ADJ 1
051-105 ENG STRUT BRKT CYL HEAD 1
051-108 STAB BRKT ALT UPPER 1
051-627 PULLEY, IDLER, 2.0IN ASSEMBLED 1
051-117 SPACER ALT STAB BRK 2
051-119 BOLT,FLANGE,M6X1.0X10 1
051-120 BOLT HEXM6X1.0X60 1
051-184 STUD,SHOULDERED,8X40 1
051-124 SKT HD CAP SCW 8X30X1.25 1
051-185 STUD,SHOULDRD,8X50X1.25 1
051-127 BOLT FLANGED 8X20X1.25 2
051-186 NUT,FLANGED,8X1.25,12AF 3
051-083 BOLT FLANGED M10X1.25X20 1
051-359 NUT,STD,M6X1.0 1
051-727 BOLT, HEX FLANGE M10-1.25 X 40 1
988-101 TENS, ASSY, LOWER 1
051-080 NUT NYLOC M10X1.5 1
051-215 SHOULDER SPACER 1
051-106 CASTING ALT MOUNT 1
051-107 ADJ BOLT, LOWER IDLER 1
051-116 SPACER IDLER STD .680 1
051-206 BOLT HEX M6X1.0X70 1
051-187 WASHER FLAT 6MM 1
051-628 PULLEY, 2.5IN IDLER, PLASTIC 1
988-206 MANIFOLD ASSY. INTAKE 1
051-098 JR BYPASS VALVE 1
051-121 AHCS M6X1.0X16 4
051-132 BARB 5/8 3/8NPT 1
051-141 BARB HOSE 90 1/4NPTX3/8 1
051-142 HOSE BARB. 7/32 VACUUM 2
051-147 BOLT BYPASS 8X16X1.25 2
051-203 PLUG,PIPE,1/8 1
051-248 BOLT, 5X20 2
051-249 TA SENSOR BLK OFF PLATE 1
051-264 INTAKE MANIFOLD, TYPE R 1
051-483 BRACKET SI HOSE 5/8 X 90 1
051-513 CLAMP HOSE NO 8 1
051-503 BOLT M 8 X .075 X 10 WI PLUG 1
051-553 CLIP RETAINING 7/32 VACUUM 1
051-554 HOSE VACUUM 7/32X9IN. 1
051-526 GASKET, TA SENSOR 1
051-529 GASKET, JR BYPASS-MANIFOLD 1
988-301 THROTTLE BDY INTAKE ASSY 1
051-265 S/C GEN3 M62CCW 4.2-4R 1
051-097 TB ADAPTOR, GSR & TYPE R 1
051-122 STUD 8X40X1.25 4
051-938 SPECIAL NUT 8X1.25 4
051-144 HOSE SILICON 1.5 IDX1.25 1
051-151 VACUUM CAP 5/32 1
051-189 CLAMP,HOSE,MINI,2INCH 2
051-212 1/8NPTX5/16BARB,90 DEG 1
051-422 BRACKET, UPPER S/C BRACE 1
051-528 GASKET,GEN3 S/C-TB ADAPTOR 1
988-409 HOSE BAG 1
051-091 CLAMP 5/8 HOSE 2
051-191 CLAMP,HOSE,MINI,#4 4
051-267 HOSE, HP FUEL,1/4X14IN 1
051-268 HOSE, VAC, 5/32X12IN 2
051-269 HOSE, HTR, 5/8X26 IN 1
051-433 FLEX HOSE 2-5/8X3X15 1
051-476 HOSE PCV 5/16X24INCH 2
051-333 HOSE, VACUUM,5/32X24IN 1
051-152 HOSE PCV 3/8X18INCH 1
051-138 HOSE FUEL,HP 1/4X20IN 1
051-190 CLAMP,HOSE,#6 6
051-240 TEE. VACUUM. 5/16 1
051-504 HOSE, COOLANT, 5/16 X 10 1
051-235 CLAMP,#44,1-3/16 - 2-3/4 2
988-501 ELECTRIC CONN KIT 1
051-493 PRESSURE SWITCH 1 PSI 1
051-101 RELAY VARIOUS 1
161-615 FEMALE SPADE CONN, 16-14 GA. 1
161-620 MALE SPADE CONN, 16-14 GA. 1
161-630 T-TAP, 22-18 GAUGE WIRE 1
356-525 HONDA WIRING LOOM 1
051-497 TERMINAL ADAPTOR 1
988-600 FUEL ACCESS KIT 1
989-505 AFPR - GSR/TYPE R 1
051-121 AHCS M6X1.0X16 2
051-146 ADAPTER BD FUEL REG 1
051-193 O-RING,M10X2.5 1
988-702 GASKETS - LOCTITE - ZIP TIES 1
051-016 CABLE TIE 8
220-136 REMOVABLE THREADLOCKER 1
051-527 GASKET, M62 S/C-MANIFOLD 1
988-809 INSTRUCTIONS & STICKERS 1
051-723 CARB EO STICKER 1
051-196 STICKER,AIR TEMP SENSOR 2
051-197 STICKER,IAC VALVE 2
051-199 STICKER,PURGE CUT SOL 2
051-200 STICKER,KNOCK SENSOR 2
051-201 STICKER,THROTTLE POS 2
051-202 STICKER, MAP SENSOR 2
051-473 JR WARRANTY CARD 1
051-477 INSTRUCTIONS.CIVIC SI 1
052-010 STICKER, 92 OCTANE 1
988-952 MANIFOLD HARDWARE 1
051-110 BELT 4PK800 1
051-118 FLANGED BOLT 6X30X1.0 3
051-131 PIPEPLUG SCT HD 3/8 NPT 2
051-135 BOLT FLANGED 8X40X1.25 3
051-207 AHCS M8X1.25X25 4
051-111 BELT 4PK610 1
051-253 GROMMET, TA SENSOR 2
051-492 PIPE CPLNG 3/8 ID HOSE-NYLN FU 1
051-479 BRKT T/CABLE CIVIC SI 1
051-480 BRKT.PURGE VALVE 1
051-696 BADGE, JACKSON RACING 2
051-109 PULLEY,ALT,DBL BELT 1
Parts descriptions that are indented
are included in item above
Bill of Materials
988-409 HOSE BAG 1
051-016 CABLE TIE 8
