should i retune
Old Mar 19, 2010 | 08:13 PM
manuel12's Avatar
Default should i retune
I was wondering if I should retune my car? When I tuned it I was running it straight downpipe. Now I put a three inch exhaust. When I tuned my car I made 300hp and 220tq on b18b. Noticed a power drop but don't how much.
Old Mar 19, 2010 | 09:08 PM
DUDMD's Avatar
Default Re: should i retune
It will run slightly richer with the exhaust on. Definite power loss will be noticeable. Good power numbers BTW
Old Mar 19, 2010 | 09:23 PM
hondapowerb16a2's Avatar
the difference between open downpipe and 3" at that power level should be minimal do you have a wideband o2? if so have your afr's changed much?
Old Mar 19, 2010 | 11:39 PM
AbitAvenger's Avatar
Old Mar 19, 2010 | 11:53 PM
_kiid's Avatar
same thing i did i tuned with dump n next day i did a 3in exhaust n it felt laggy alil
Old Mar 20, 2010 | 06:52 AM
manuel12's Avatar
It does seem to run richer. Do you guys think I should retune or waste of money for that little difference?
Old Mar 20, 2010 | 07:55 AM
DUDMD's Avatar
A retune shouldn't cost you that much, call your tuner and see what he thinks and what he''ll charge to change the tune.
Old Mar 20, 2010 | 09:40 AM
HamiltonRex's Avatar
if you have any other parts you would like to get put on, IE. intake manifold, injectors, maybe race gas? Then you should get those parts in and go back for a tune.
Old Mar 20, 2010 | 04:23 PM
manuel12's Avatar
Alright gonna call tuner to ask if worth to tune over. I am gonna gonna put anything else for the moment.
Old Mar 20, 2010 | 04:47 PM
sleepencivic's Avatar
do you run a wideband? if so what are your afr's in boost after the change?
Old Mar 20, 2010 | 05:06 PM
manuel12's Avatar
Yea I run a wideband. Usually at idle I am in the 12:1 range.
Old Mar 20, 2010 | 07:08 PM
Turbo-LS's Avatar
jesus 12:1 range at idle who tuned your car? its worth retuning
Old Mar 20, 2010 | 07:21 PM
qQQp's Avatar
^which a/r ratio at idle should be?
Old Mar 20, 2010 | 07:23 PM
Turbo-LS's Avatar
14's 15's not 12's
Old Mar 21, 2010 | 01:59 PM
yea that rich, like said above aim for 14.5-15.5 at idle, 11.5-12.0 in boost for pump gas depending on your set-up and tunners guts
Old Mar 21, 2010 | 06:22 PM
EGhatch87's Avatar
+1, what are you AFRs in boost
Old Apr 4, 2010 | 04:57 PM
manuel12's Avatar
took it to get it retuned. First i got 300hp and 220tq open downpipe. Put a 3 inch exhaust and started to run rich so i got it retuned made 308hp and 255tq. runs way better now worth it.
Old Apr 4, 2010 | 05:45 PM
manuel12's Avatar
CHARTS
File Type: zip
Old Apr 4, 2010 | 07:21 PM
DUDMD's Avatar
thanks for the graphs, whats done to the LS?
My del sol with an LS should put down similar but higher HP.
Im surprised running a 3" exhaust bumped up your torque that much.
Old Apr 5, 2010 | 05:09 PM
manuel12's Avatar
It has stage 2 cams and valve spring and retainers. Rc 550cc injectors.
Old Apr 5, 2010 | 09:14 PM
DUDMD's Avatar
wow, same here. I got the crane all motor stage 2 cams, crower springs and retainers and same injectors.
Took it to the dyno today, my dizzy was on its last legs, kept on breaking up.
I would love to see some videos on how it rips.
Old Apr 6, 2010 | 10:29 AM
LightningTeg's Avatar
Community Builder
Originally Posted by manuel12
CHARTS
So what did it make on the same boost as the open downpipe with the full exhaust?
darkvader0
Jan 22, 2010 04:26 PM
HickamHatch
Dec 16, 2009 10:51 PM
Otis37
Aug 15, 2009 11:55 AM
stalyun
Apr 28, 2009 08:59 PM
boostjunkie757
Dec 30, 2004 09:19 AM
