ZEX Wet kit converted to dry???
Re: ZEX Wet kit converted to dry???
Well considering a wet kit is both a nitrous solinoid and a fuel solinoid. so i would assume you could easily run just the "dry" portion of the kit just fine.
Yes it is, i did this to mine years ago and it worked fine. The two solenoids are mounted in the zex case side by side, if you cut the wires to one of the solenoids and remove it the control unit is not effected.
Double 06
06-03-2002 08:31 PM
