Feed line size for 6765
Old Mar 19, 2010 | 06:09 PM
civicgsrturbo32's Avatar
Default Feed line size for 6765
Just got my precision 6765 I was wondering what size feedline I should be using? My motor is a built Gsr type r oil pump. I just need to know if I have to run a -4 or -3 line. If you guys could help me out that would be great.
Old Mar 19, 2010 | 08:26 PM
ScorpionT's Avatar
Default Re: Feed line size for 6765
Ball bearing or journal? I would run a -4 for journal, and either -3 or -4 for DBB. The new DBB have built in restrictors, nice feature.
Old Mar 19, 2010 | 08:30 PM
I should have mentioned it was a journal bearing. My bad.
Old Mar 20, 2010 | 10:36 AM
Tjabo's Avatar
Subscribed. I'm trying to sort this type of an issue right now with my 6265.
Old Mar 20, 2010 | 10:43 AM
92redhatch's Avatar
I run a -4 because precision said so. I personally think a -3 would be better but I run a -4 to make sure I cover my *** if anything happens to the turbo
Old Mar 20, 2010 | 10:46 AM
90blackcrx's Avatar
We run a -4 , its what precision recommends. We also run an inline oil pressure gauge on each setup though to determine what oil pressure at the turbo is.
Old Mar 20, 2010 | 10:48 AM
Tjabo's Avatar
What is your drain like, and what oil pressure do you have at idle? What is your idle RPM? These seem to be the pertinent questions that determine whether you are a candidate for a bit of oil burning at idle. I'm heading out to the garage in a few minutes to upgrade my drain.
Old Mar 20, 2010 | 10:54 AM
I guess I'll run a -4 so it covers my *** too
Old Mar 20, 2010 | 10:58 AM
O also should i run it with or without a oil restrictor?
Old Mar 20, 2010 | 11:24 AM
ScorpionT's Avatar
Without a restrictor. If you have oil passing by the control rings or smoking, use a -3 line.
Old Mar 20, 2010 | 12:40 PM
Thanks for everyones help
Old Mar 21, 2010 | 05:56 AM
Tjabo's Avatar
In that case you wouldn't have any concerns about oil starvation on the bearings?
Old Mar 21, 2010 | 09:26 AM
ScorpionT's Avatar
Nope. If you have oil leaking then you have too much pressure/volume. The -3 line would reduce it enough and still be safe.
Old Mar 21, 2010 | 09:29 AM
Tjabo's Avatar
Alright, thanks!
I'm massively upgrading my drain today, so if I still have issues, I may just go that route next.
roc0487
Dec 30, 2019 02:14 PM
SPOOLINmatt
Jun 4, 2012 07:17 AM
golf-mk3
Mar 24, 2011 04:02 AM
sohczcturbo
Feb 10, 2007 08:54 AM
1.8T_EG
Sep 26, 2002 07:07 AM
