Good level to set boost at
Old Mar 31, 2010 | 05:52 PM
Str8fourvtec's Avatar
Default Good level to set boost at
Hey guys i've got a JDM b16a in my 94 ls and wondering what kind of pressure i can run with a stock bottom end....everything else is fully built except for the internals of the motor...its set at 8 psi right now....lemme know
Old Mar 31, 2010 | 06:02 PM
YARO.'s Avatar
Default Re: Good level to set boost at
psi by itself doesn't mean anything. What turbo and what else does the setup consist of?
Old Apr 4, 2010 | 08:02 PM
its a garrett t3/t4 t04e .50 AR. intenrals are stock, its a JDM B16A with a Type R trans bolted to it. all the necessities for a turbo build are on the car.
Old Apr 4, 2010 | 08:09 PM
boostedEF91's Avatar
pump gas around 330hp you'll be safe. psi on that turbo will probably be around 14 to 16psi to make that power
carlosjdmcivic
Mar 9, 2010 07:13 AM
trigger_time
Mar 11, 2009 06:58 AM
92 white eg
11
Jul 23, 2007 02:40 PM
eghatch16
Nov 2, 2006 04:55 AM
Boring
18
Feb 9, 2005 02:45 PM
