deg. on cams??
Old Mar 22, 2010 | 09:38 PM
runsfromdacops's Avatar
Default deg. on cams??
ok guys im going to the dyno in the next day or two. i would like to know what you guys run your cam gears at. so i have a good starting point.
the setup.
:head
ported gsr head w/ race cut guides by rocket motorsports
rocket motor sports valve train
ferrea .5+ valves
blox Bs
ported jg IM(cast)
68mm TB
block:
GE sleaved block 84.5mm
9.7-1 comp CPs
eagle rods
ls crank
turbo kit
full race ramhorn
t67ho.w.63ex
3" dp
afi 1000hp IC
devils own meth kit. running 50/50 water/meth
1200cc msd injectors
also what do you guys think it will make on pump gas and water/meth?
Old Mar 23, 2010 | 09:24 AM
dart2.2's Avatar
Default Re: deg. on cams??
have your engine degreed to what the cam manufacturer recommends.
Old Mar 24, 2010 | 07:49 PM
i dont think i have ever herd of any manufactures giveing any kinda advice on came gear set up...
Old Mar 24, 2010 | 08:15 PM
rat city rex's Avatar
Why dont you give Ross nog a call, Are you having dave tune it? Ask him too.As for power I think you will make 708whp on meth, Thats what bisimoto made on pump and meth...lol
Old Mar 25, 2010 | 04:45 AM
dart2.2's Avatar
never said they give advice on cam gear setup. search the mike belben engine degree kit.
Old Mar 25, 2010 | 09:31 AM
i will give to old rossanter a call. and see wahat dave has to say about it but i was just trying to have it all ready for him so he can show up and get to tuneing
dart: im sorry i think i mis spoke in my 1st post im just looking for cam gear setup on my cams. not looking for deg the motor as a whole.
-alex
Old Mar 25, 2010 | 10:01 AM
narfdanarf's Avatar
-alex
Those are the same things. The problem is that Blox is a replica company so they don't provided detailed instructions for degreeing because they have no idea what it should be. I would put them at 0,0 and see what happens. But you can't rightly start somewhere if you don't know the p2v and v2v clearance you have at that point. 0,0 on my pro1's would have had catastrophic failure.
Old Mar 25, 2010 | 10:14 AM
its running right now at 0,0 and hasnt smashed anything yet lol.i just wanted to see if there is a common setting that makes the best power, i geuss its more of a case by case typ of thing.
DA 4 Lyfe
Nov 30, 2013 09:14 AM
killacamcivic
Sep 5, 2013 02:54 AM
greyEG
10
Sep 5, 2012 01:56 PM
matttegra
Jul 10, 2009 10:56 PM
highvelocityteg
12
Aug 3, 2005 07:58 PM
