Need Help Identifying Turbo
Do you know the a/r sizes of the compressor side and exhaust side. If the turbo isnt ball bearing there really is no use for a restrictor, and you will need a 5 bold exhaust flange. Hope that helps you out.
I had the same question regarding my Garrett .57trim and posted this thread not too long ago>>>>
https://honda-tech.com/forums/forced-induction-16/oil-restrictor-yes-no-2730302/
As you'll notice, there are ALOT of different, good opinions from some people on HT that know there stuff. I run a .065 restrict-or flange on my btw... GOOD LUCK!!!
Run a restrictor. You will need one. Turbos only need around 10 psi of oil press. Now think if you ran 70+ lbs of psi what it would do? It will push past your oil contole rings and it will then smoke.
Well I decided to use a .060 restrictor, now I am just trying to find a downpipe flange. The normal t3 five bolt flange just doesn't line up.
