Head Gasket Head studs?????
Old Mar 25, 2010 | 02:31 AM
1990hondacrx's Avatar
Icon2 Head Gasket Head studs?????
I have a 91 Honda crx with a b16a bone stock with turbo on 11psi in it... temperature finally changed and its not in the 20's i drove the car and notice it started to over heat and started smoking every time the thermostat would basically open..
my question is what are good head gaskets to run with a lot of people i hear stay with stock I'm going to be putting more boost threw it soon to around 14 to 16 pounds.
I'm going to buy ARP Head studs but just wana know what is a good head gasket stay with stock or is there something better.
Also i have another b16a head from my obd0 b16a engine with all CTR Valve train in it would it be a good idea to go ahead and change it over to it now? and would it be a good idea to get it resurfaced?
so main questions?
what kind of head gasket ?
what kind of head studs ?
and resurface the head even though the block wont be resurfaced ?
Old Mar 25, 2010 | 04:38 AM
Default Re: Head Gasket Head studs?????
bump need sum help fast please
Old Mar 25, 2010 | 04:56 AM
kyden's Avatar
oem headgasket. arp studs.
surfacing depends on how flat your surfaces are.
Old Mar 25, 2010 | 06:38 AM
come on honda tech hell just say what your running atleast and how many pounds and how long
Old Mar 25, 2010 | 10:13 AM
NonovUrbizniz's Avatar
Loved
almost everyone uses stock HG's and ARP head studs... the end.
As far as resurfacing as said above it depends on how true they are now... and resurfacing just the head if it seals well now could cause leaks if you're not decking the block too.
Old Mar 25, 2010 | 10:46 AM
CerealKiller's Avatar
This, but I prefer GE head studs (just choice).
Old Mar 27, 2010 | 11:08 AM
TEAM ASSASSIN SI's Avatar
i personally prefer cometic head gaskets and arp head studs this things are automatic on a build bro.
Old Mar 27, 2010 | 11:14 AM
SpoolnG2's Avatar
Stock JDM ITR block & b16 head. Im using a 3mm Inline Pro headgasket with ARP studs. Running 12psi on a mild tune, this being my third season with this setup.
Old Mar 27, 2010 | 11:37 AM
Kyle R's Avatar
Old Mar 28, 2010 | 09:59 AM
zedron's Avatar
Cometic HG with ARP studs. Going strong for 4 years now @ 16lbs.
Old Mar 29, 2010 | 03:20 AM
awesome so a lot of people i see are running OEM Honda head gaskets. Even for MEGA power builds and that's what Jeff Evans even suggest for people to use.
OEM with studs anyone have a part number for a obd1 b16a OEM head gasket? so i can get it ordered i have this part number 12251-P30-014 is it correct?
im going to be running a obd1 b16 block with a b16a obd0 Head
Old Mar 29, 2010 | 04:19 AM
non-VTEC's Avatar
oem gasket and GE studs here......
Old Mar 29, 2010 | 08:17 AM
Can anyone verify that this is the correct part number or tell me what the correct part number i should use is for the head gasket?? 12251-P30-014 I have a b16a obd1 block with a b16a obd0 head
Old Mar 30, 2010 | 01:09 AM
Old Mar 30, 2010 | 04:34 AM
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
Prelude900
May 10, 2015 02:47 PM
austincrx
Sep 7, 2006 09:49 AM
snatchback
Jul 5, 2006 08:47 PM
bdicustoms
Aug 25, 2004 07:35 PM
