JRSC sensors ???
Old Mar 23, 2010 | 08:29 AM
andrew1's Avatar
Default JRSC sensors ???
what sensor go here
Old Mar 23, 2010 | 09:08 AM
Jaker's Avatar
Default Re: JRSC sensors ???
That port is not for a sensor. It is for a water injection nozzle or a nitrous injection nozzle, or some other "extra" system/part that you chose to use. There is no Honda OEM sensor that needs to go there.
Old Mar 23, 2010 | 12:53 PM
andrew1's Avatar
ok ...whats in this one i have seen this alot
http://images.nikonians.org/gallerie.../7731/jrsc.jpg
Old Mar 23, 2010 | 01:29 PM
bsclywilly's Avatar
It's a pressure swith that comes with the kit. It switches a relay that bypasses the AT sensor signal to the ECU with a resistor. When you reach boost, it makes the ECU think the air is cooler than it is to provide enough fuel.
Old Mar 23, 2010 | 01:59 PM
andrew1's Avatar
do i need it
Old Mar 23, 2010 | 08:08 PM
Jaker's Avatar
Crap! I forgot about that thing. What kind of fueling/engine management are you using with your setup?
If you're doing the JRSC FMU with your engine, then yes, it's a good idea to use that IAT band aid to help with fueling. If hwoever you're using bigger injectors and some sort of ECU tuning, then you do not need it at all.
Old Mar 24, 2010 | 05:48 AM
andrew1's Avatar
yea im going to use an fmu
Old Mar 24, 2010 | 07:28 AM
bsclywilly's Avatar
yup, what Jaker said.
BigJ5
Apr 19, 2008 08:06 PM
Tonyl507
Feb 12, 2007 06:35 PM
keebler65
Jan 21, 2005 03:00 PM
Zero2Sixty
Apr 4, 2003 02:43 AM
