Question about supercharged k-series horsepower.
I am new to the site please don't delete this if it is in the wrong spot I'm sorry.
I recently bought an wrecked 2003 rsx type-s for the motor swap because it has a supercharger. I thought the car was stock with a jrsc on it but when I got it home, I found out it had more done to it than what I thought. What want to know is how much horsepower should make with this setup and what it should run in a quarter mile? It is going in an EM1 with the K-swap header and Hybrd fuel rail and borla exhaust.
This is what I know about it......
jackson racing supercharger 10.5 lbs boost pulley
K24a1 cr-v block k20a2 type-s head (I don't know if anything has been done to the engine)
2002 rsx type-s transmission
rc 650cc injectors
k-pro
AEM intake
Thanks
Cyle
rc 650cc injectors
k-pro
AEM intake
Thanks
Cyle
Re: Question about supercharged k-series horsepower.
Always nice to pay for one thing, and end up with a huge bonus like that. You're a lucky SOB!
Go ask on www. c l u b r s x .com (take out the spaces). There's lots of guys working on JRSC setups over there. There might also be a bunch of info here in the RSX/EP3 forum (https://honda-tech.com/forums/acura-rsx-dc5-honda-civic-ep3-32/).
Thanks jaker i'll check that website. I know its a decent setup but is it pretty dependable ? I'm wanting to hit 300whp is this possible ?
with the K24 block i would assume it would be possible heres a quote from a thread i read awhile back heres the link
https://honda-tech.com/forums/forced-induction-16/dyno-test-water-methanol-injection-m62-supercharged-k20a2-2540440/
Here is a comparison of the final meth OFF vs. meth ON graphs.
The setup consists of:
Stock-block K20A2
JRSC (EP3 manifold)
TDM Tri-Y header
3" Thermal exhaust
K-Tuned 3" cold air intake
RC 750cc injectors
K-Pro
CoolingMist methanol kit controlled through K-Pro (as well as fuel and ignition control for such)
- Derek
Stock-block K20A2
JRSC (EP3 manifold)
TDM Tri-Y header
3" Thermal exhaust
RC 750cc injectors
K-Pro
- Derek
300-340whp~ depending on how aggressive the tune is. If you can swap it out for a Rotrex supercharger you'll end up with alot more 400+whp all day.
Regardless it should be a fun car with the jsrc I think there is a 12psi pulley for the jsrc as well as custom pulleys for more power.
