Louder than normal skunk2 valvetrain
Old Apr 3, 2010 | 06:36 PM
rdeezy78's Avatar
Icon2 Louder than normal skunk2 valvetrain
A while ago I did a 4th gear pull on the highway. After the pull I noticed a ticking in my head area. My oil level was kind of low the following morning when I checked after noticing the ticking. I have pro 1 cams, pro springs, retainers, and valves. Fresh head build. Car is tuned with Neptune eprom. Recently ajusted valves to .006 in and .007 ex and the ticking is still there. It sounds like it's just in either the 1 or 2 cylinder but i could be wrong.It doesn't get any quieter after the car gets warmer. Not sure what a piston and valve hitting sounds like, but it does sound like something may be touching. If that makes sense. Cams I beleive were set to 0 before the tune. Camn anyone offer any helpful suggestions to what the prob may be. thanks
Old Apr 4, 2010 | 10:47 AM
rdeezy78's Avatar
Default Re: Louder than normal skunk2 valvetrain
no thoughts at all guys????
Old Apr 4, 2010 | 06:09 PM
rdeezy78's Avatar
bumping for help.
Old Apr 4, 2010 | 10:33 PM
david974's Avatar
make a compression test to see if you could have a sligh bent valve
did you re check your valve lash since the noise coming
regards
rdeezy78
Apr 7, 2010 05:32 PM
emaka9
Dec 23, 2007 04:51 PM
koczeka
29
Jul 16, 2006 11:43 PM
gsrjay
Aug 23, 2004 01:40 PM
THE GUY
Mar 21, 2003 07:36 PM
