Bottom End Build Help
Old Mar 25, 2010 | 04:33 AM
Str8fourvtec's Avatar
Default Bottom End Build Help
Hey guys i have a built b16a turbo'd of course but want to build the bottom end to be able to turn up the boost.....looking for input and reviews pros and cons of some low comp pistons and some strong rods....lemme know what ya got and if you like them as well as what kind of boost you're running.....thanks
Old Mar 25, 2010 | 10:16 AM
NonovUrbizniz's Avatar
Loved
Default Re: Bottom End Build Help
what are your goals the stock bottom end can handle a lot of power.
Old Mar 26, 2010 | 04:59 PM
i wanna be around 350-400
car completely built except for internals...
Old Mar 26, 2010 | 05:04 PM
its a JDM b16a from japan and has a type r trans hooked up to it....also would 9:1 comp pistons work good for turnin boost up? with eagle H rods
Old Mar 26, 2010 | 05:32 PM
TEAM ASSASSIN SI's Avatar
9:1 comp. is good and i believe those rods are good for 600hp i run bc rods and wiseco pistons with alot more power than you looking to make with 0 problems hope that helpss
Old Mar 26, 2010 | 05:46 PM
ya i was in the marketplace and found that modernhonda can get a set of rods and pistons for 750 shipped, wiseco and eagle
fusion645
Jan 2, 2010 05:47 AM
Citystar
Jun 23, 2004 06:20 PM
Slimm-rw-
May 3, 2004 01:06 PM
ELSpool
Jun 11, 2003 09:12 AM
n-boost
Jan 9, 2003 10:19 PM
