Oil pans
Old Mar 18, 2010 | 07:26 PM
fusion645's Avatar
Icon2 Oil pans
I'm running a turbo set up this year. I'm going to use the golden eagle sandwich adapter for the turbo oil feed line. The question is... should i use a stock type r oil pan or moroso oil pan?
The turbo is a T3/T04E
Old Mar 18, 2010 | 07:31 PM
Turbo-LS's Avatar
Default Re: Oil pans
stock pan an dhave bungs put on it. no need for a moroso pan
Old Mar 18, 2010 | 08:26 PM
fusion645's Avatar
I would be fine if i use that golden eagle sandwich adapter right? I was going to use that for the oil return feel line.
Old Mar 19, 2010 | 04:31 AM
kyden's Avatar
what? its for oil feed only, not return.
Old Mar 19, 2010 | 04:32 AM
Turbo-LS's Avatar
no the sandwich plate supply oil pressure to the turbo. you have to get a bung welded into the pan for the return
Old Mar 19, 2010 | 07:08 AM
dpetro1's Avatar
what engine do you have? oil pans are not all interchangeable so using a "type-r" pan may not be a good idea. also oil pans and turbo type are not related. also a sandwich adapter has no effect on your oil pan. use andwich adpater to feed the turbo then return oil to your stock oil pan. keep researching
Old Mar 19, 2010 | 01:42 PM
DA TeG 90's Avatar
OEM oil pan is the way to go.
ashb82
Mar 22, 2010 12:50 PM
dart2.2
Jul 25, 2008 07:01 AM
swatteamtimmah
May 7, 2006 04:19 PM
