d16z6 turbo - Final processes
Old Mar 19, 2010 | 11:19 PM
blasta510's Avatar
Default d16z6 turbo - Final processes
Here is the deal.
I just got this car 2 weeks ago.
It is a 1994 civic.
has a d16z6 that has been fully built and turboed.
It has only 900 miles on the motor since being built - has stock injectors- stock map sensor- stock ecu - no tune. Currently at 4 psi.
I have just bought 1000cc Rc injectors and a 3 bar map sensor
I beleive the turbo is a Garett m12 .57 trim.
Anyhow i am planning on taking the car to have it dyno tuned at Revolutions Performance in Colorado Springs, Colorado her in about 2 weeks when their new shop opens up. I am planning on running it at around 20 psi - and expect around 350 + hp.
Any suggestions on what i should do to the car?
My plan is to have it street-able - but also take it to the drag strip every once in a while.
The fuel system has been fully built for e 85 but is currently running on pump gas. Should i have it tuned for both? Just 91? or Just e 85 - problem i am thinking with e85 it their is only 3 stations in my city and they are 15 miles from my house.
I am currently upgrading a few of the silicone couplers and getting t-bold clamps.
What do you think?
Old Mar 20, 2010 | 09:52 AM
shifty35's Avatar
Default Re: d16z6 turbo - Final processes
Well, it looks like you'll get to upgrade your turbo manifold once it cracks.
Other than that, you'll probably want beefier-than-stock motor mounts and some suspension work to make it hook.
LSD is a huge plus for the street.
Old Mar 20, 2010 | 10:00 AM
boosted94gsr's Avatar
You need to get that tuned asap! I dont know how that motor lasted that long even at just 4 psi without a tune. If ur gona keep driving it maybe disconnect the charge piping until u get a tune.
Other then that nice lookin setup. Good luck.
Old Mar 20, 2010 | 12:18 PM
namewasdallas's Avatar
id get a new downpipe that thing looks tiny, also do a tune up wires plugs and oil, change the tranny fluid, get a boost controller as well
Old Mar 24, 2010 | 09:27 PM
blasta510's Avatar
Well i got a few parts
The piping had some crappy rubber hose connectors so i ordered some silicone ones from www.siliconeintakes.com along with some t-bolt clamps and and air filer- the stuff was pretty cheap and seems like it is good quality accept the air filer- it was paper thin and had holes in the filter material - cant expect much for 15 bucks-its getting returned.
What else can i do with the air filter setup???? Suggestions?? I don't have very much room. And the filter that is on it now seems to small.
Should be getting it tuned in a week or so.
I replaced this crappy hose ^^^^
What is this oil doing here, Is this bad?? ^^^
Old Mar 24, 2010 | 10:00 PM
TehGhett0P1mp's Avatar
Oil on the turbo is bad because it seems you have a POS ebay turbo kit with turbos that are nortorious for blowing the seals. If anything you should have used a restrictor if you wanted to run that turbo.
Also I would get a different turbo manifold unless you want your ebay wastegate in the street.
Sorry if I sound harsh, but it just makes me sick to see people waste money on BS.
Old Mar 24, 2010 | 11:27 PM
blasta510's Avatar
I bought the car like that.
What manifold would you recommend? Cast?
Also what turbo would be good? For around $300 rebuilt.
What would be the side effects if i have the car tuned with this turbo?
Old Mar 29, 2010 | 02:10 PM
blasta510's Avatar
How many people have their cars daily driven tuned on e85?
g.r.crx
Engine Management and Tuning
Feb 16, 2013 12:50 PM
Elevorett
Jun 28, 2009 06:01 PM
dturbo
Jul 2, 2007 10:00 PM
miro_gt
Jan 21, 2007 01:40 AM
VtecbOi
Dec 26, 2003 05:11 PM
