Updated pics of the project.
Old Jun 11, 2003 | 08:38 PM
b18cx's Avatar
Default Updated pics of the project.
Finally got the car back last Friday. Been busy getting all the electrics and brakes back in. Lot of work, but definatly worth it. Shouldnt be long now. Dont pay any attention to the black tape, new windshield.
The begining
Some resembly done.
Now some pics of the motor and new turbo. Dont flame me too much on the manif. With a little touch up welding and a little bracing I dont see any future problems.
Notice the upside down L shaped brace. Carries almost all the weight of the turbo. No weight on the manifold. Check the second pic for where it attaches to the bolck.
The next time I post It should be done and I'll have some dyno numbers up.
Modified by b18cx at 6:17 PM 6/12/2003
Old Jun 11, 2003 | 08:41 PM
Flamenco-T's Avatar
Default Re: Updated pics of the project. (b18cx)
NICE, did you have to undo the hard brake lines when you're painting the engine bay ?
stan
Old Jun 11, 2003 | 08:44 PM
b18cx's Avatar
Default Re: Updated pics of the project. (Flamenco-T)
Stripped to the bone.
Old Jun 11, 2003 | 08:56 PM
Broken Gearbox's Avatar
NICE stuff doode!
Old Jun 11, 2003 | 08:58 PM
boostin b16's Avatar
nice
what size down pipe is that?
the mani should do fine. even though they get a bad rap, they do make power and with a little bracking and milling the dont crack!
Old Jun 11, 2003 | 09:02 PM
b18cx's Avatar
Default Re: Updated pics of the project. (boostin b16)
3 inch down pipe
Alittle info on the set up : NEW SC61, 720cc injectors, Hondata s200, and all the little stuff. Gona run 10psi for now (Tony1 tuned) untill I build the bottom end next spring. Stock JDM GSR. Should be fun for a while.
Old Jun 11, 2003 | 09:06 PM
Danger's Avatar
car is coming along nicely
Old Jun 11, 2003 | 09:09 PM
metal-x's Avatar
Your setup looks very nice.. quick though question since I have a JDM gsr motor as well whats the max boost you'll take it?
Old Jun 11, 2003 | 09:17 PM
b18cx's Avatar
Default Re: Updated pics of the project. (metal-x)
All in the tuning. Plan on 10-11. If I get the 3bar map I might go for 12-14. Really depends on what Tony1 thinks.
keebler65's Avatar
that bay is freakin' CLEAN
Old Jun 12, 2003 | 09:18 AM
b18cx's Avatar
Default Re: Updated pics of the project. (keebler65)
Thanks.
Old Jun 12, 2003 | 10:47 AM
SOHC_power's Avatar
Wow, I wish I was a baller
Old Jun 12, 2003 | 04:01 PM
FredoSP's Avatar
Old Jun 13, 2003 | 09:40 PM
b18cx's Avatar
Default Re: Updated pics of the project. (FredoSP)
thanks for the response.
Old Jun 14, 2003 | 05:52 AM
hired gun's Avatar
Eric, you always seem to amaze me with all the work you do to our cars and yours. He never half asses anything. Back in the day(5 years ago) he built a 92 SI w an LS that ran 13.0's on stock fuel, bottom end and JG cams!!
BTW, shuweet trailer
Old Jun 14, 2003 | 06:04 AM
tony1's Avatar
Default Re: Updated pics of the project. (hired gun)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hired gun &raquo;</TD></TR><TR><TD CLASS="quote"> Back in the day(5 years ago) he built a 92 SI w an LS that ran 13.0's on stock fuel, bottom end and JG cams!! </TD></TR></TABLE>
That's just cause i tuned it j/k Eric, you do very nice work!
Old Jun 14, 2003 | 07:30 AM
quikB18B's Avatar
Default Re: Updated pics of the project. (tony1)
Thats what you call a project. Nice job, nice setup
Keep us updated i want to see more magical #'s with the sc61.
Old Jun 14, 2003 | 10:12 AM
JUNcr-x's Avatar
Default Re: Updated pics of the project. (quikb20)
good work !! set up looks nice
Old Jun 14, 2003 | 10:38 AM
b00stedbyFastrax's Avatar
Default Re: Updated pics of the project. (b16t4_cr-x)
nice set up! just out of curiousity, the oil return to the oil pan, as it being so low, wouldn't it cause a problem?
Old Jun 14, 2003 | 12:22 PM
JDM92CX's Avatar
Default Re: Updated pics of the project. (BoostedbyFastrax)
It can't no better than that.
Old Jun 14, 2003 | 12:54 PM
b18cx's Avatar
How could it cause a problem? Its about as straight down as you can get. Dont forget that an oil return for a turboed honda is gravity feed.
Old Jun 14, 2003 | 01:11 PM
Sleek98's Avatar
how long did it take you to strip out the entire car to paint everything??? In your opinion was it worth gutting the entire thing to a shell to paint? nice job btw..
Old Jun 14, 2003 | 01:13 PM
DB2's Avatar
DB2
Default Re: Updated pics of the project. (Sleek98)
What color (specifically) is that? Looks darker than anything like VSM. Car/turbo/engine look awesome!
Old Jun 14, 2003 | 02:55 PM
TURBO B's Avatar
what exhaust manifold is that
Old Jun 14, 2003 | 03:05 PM
intekragsr's Avatar
Nice work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx &raquo;</TD></TR><TR><TD CLASS="quote">How could it cause a problem? Its about as straight down as you
can get. Dont forget that an oil return for a turboed honda is gravity feed. </TD></TR></TABLE>
I believe what he means is that the pan is tapped too low. Where the line sits on the pan, it will be hard to drain since its going into the bottom of the oil, causing the line to be backed up. There is no pressure to push the oil from the line, into the bottom of the oil pan. If it was tapped higher on the pan, it would just drip into the oil from the top with no effort. I hope you see what Im saying. I would shorten the line, tap about 1-2 inches higher and 1-2 inches towards the flywheel.
Besides that
