blowoff in neutral?
Old Jun 11, 2003 | 09:55 PM
xstalkrx's Avatar
Default blowoff in neutral?
I know that turbo eclipses have a loud blowoff when reving in neutral.
However, Integras don't seem to blowoff while revving in neutral with no real load on the engine. Is there a reason for this?
Old Jun 11, 2003 | 10:40 PM
krazy's Avatar
Default Re: blowoff in neutral? (xstalkrx)
i think because stock turbo cars run off pressure while our cars run off vacuum. like if u disconnect an intercooler pipe of theirs, the car wont start. thats how my friends mr2 is.
krazy
Old Jun 11, 2003 | 10:50 PM
intekragsr's Avatar
Default Re: blowoff in neutral? (krazy)
because stock turbo cars come with smaller turbos than our turbos. If you want to blow off in neutral, raise your compression to 11:1 and slap on a t25.
Old Jun 11, 2003 | 11:04 PM
pissedoffsol's Avatar
25 Year Member
Default Re: blowoff in neutral? (intekragsr)
having a MAF helps too...
Old Jun 12, 2003 | 02:29 AM
swlabhot's Avatar
Small displacement and big turbo = no blow-off...
OEM turbo cars normally comes with a small turbo and are generally 2L + hence you don;t need a load on them to get a blow-off...
Old Jun 12, 2003 | 03:18 AM
T-Blaze's Avatar
So how do u explain ur situation??? U seem to blow off at any chance u get.. And I don't see a turbo in sight.
Old Jun 12, 2003 | 04:02 AM
swlabhot's Avatar
Default Re: (T-Blaze)
Dats cos my snail runs @ 100+ psi on each butt cheek..
and 50psi per bollock
Old Jun 12, 2003 | 04:33 AM
GreddySi99's Avatar
Default Re: (swlabhot)
Now lets ask this question. why would you want to blow off in neutral anyway Sounds like some riceboy ****
Old Jun 12, 2003 | 04:38 AM
swlabhot's Avatar
Default Re: (intercooledJRSC)
Not that I can blow off in neutral, but blowing 0ff in neutral is ricey?!?! Wot is the world comin to?? Next thing u gonna say havin a car is ricey, especially a Honda
Old Jun 12, 2003 | 05:06 AM
T-Blaze's Avatar
Well when I turned the boost up to like 9ish psi I have found that it does blow off in neutral... It never used to at 6.5psi!!
Sounds good..
Old Jun 12, 2003 | 05:16 AM
TKERacer619's Avatar
Yea it would be nice to be able to Blow Off sitting in traffic......... I dont think it is nessacarily ricey hahaha of course i have altezza's so in effect I am a rice boy so my vote doesn't count............. Rice is made by short people in flooded feilds. I have always pondered as to why the main staple of many cultures is used on import boards as a discrace. I mean isn't all rice JDM. Isn't that cool ?? Is it because there is so much of it and so little flavor? But then some would argue that its the way you cook it......... my .02
Old Jun 12, 2003 | 06:27 AM
MotorMatrix.com's Avatar
I am a bad person
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by intekragsr &raquo;</TD></TR><TR><TD CLASS="quote">because stock turbo cars come with smaller turbos than our turbos. If you want to blow off in neutral, raise your compression to 11:1 and slap on a t25. </TD></TR></TABLE>
rival12
Mar 22, 2004 10:44 AM
platinum00
Mar 9, 2004 06:12 PM
X2BOARD
Aug 23, 2002 01:22 AM
Hondasaurs
Nov 5, 2001 07:38 PM
