Hondata question
Old Jun 14, 2003 | 05:15 PM
hybrid901's Avatar
Default Hondata question
I just installed a hondata 2b into a guys car and I'm having a few problems. First the red light is flashing and it has a rev limiter of 4k. If the program is for a 3 bar map sensor and the car has a stock map could that be a problem?
Old Jun 14, 2003 | 05:30 PM
boosted hybrid's Avatar
Default Re: Hondata question (hybrid901)
That could very likely be the problem. The blinking red light signifies a incomplete Rom image, or a problem with the ecu type selected than what is being used. Also make sure the rom image wasnt created for the s100/s200 V3 software and not converted back to the 2b/3b V2.5.
Old Jun 14, 2003 | 06:23 PM
hybrid901's Avatar
Default Re: Hondata question (boosted hybrid)
I'm sorry its a s200. The ecu is a p06 and is running a ls program. The check engine light stays on and when I check the code the light doesn't blink either.
Old Jun 14, 2003 | 11:04 PM
Sleek98's Avatar
i was having this problem tonight speak of the devil...but my problem was the plug inside the ECU kept moving around a bit, and not getting a solid connection...
Old Jun 15, 2003 | 11:57 AM
Spunkster's Avatar
Who socketed the ECU? Did you rewrite the map to use the stock map sensor instead of the 3-bar?
Old Jun 16, 2003 | 12:08 AM
BoosterChair's Avatar
Default Re: Hondata question (Spunkster)
except that probably wasn't the problem drew, that connection was solid when i was testing it later and it wouldn't even idle, and the wiring harness is not the problem, dale just doesn't want to admit that it might be the unit or his earlier oversight
i have p72 s200 w/boost went to race bike on highway, hondata crapped out
Old Jun 16, 2003 | 05:13 AM
hybrid901's Avatar
Default Re: Hondata question (BoosterChair)
Hondata socketed the ecu and alamo burnt the map. I'll find out today if its burnt for a 3 bar or not.
EG6_978
Aug 3, 2008 05:56 PM
eg2tr
Jan 5, 2008 09:36 PM
PreludePhill
May 24, 2007 08:18 PM
B18C1CYA
Apr 17, 2004 09:00 PM
