help me diagnose the headgasket leak... AGAIN
1 Post
I can never get this head gasket to seal. I've got a b18c... I just rebuilt it. Decked block, resurfaced head. New head gasket (it was a p30 gasket, but it lined up perfectly with my old p72 gasket). ARP headstuds, and I had them in before I blew the motor, so they had the 10 head cycles and the retoqrue following thatr. I'm getting oil from the corner were is says b18c, and I can seeit where the block meets the head (if I'm under the car) in front of hte block, (the side where the dipstick is). I torque it to spec, in helms order. Any idea?
I will retorque it tomorrow (first time since rebuild). If that is the problem, then will it be screwed even if I reqortue it because oil has already seeped past it?
1 Post
Re: help me diagnose the headgasket leak... AGAIN (servion)
whoa I had the same problem before. Not sure of the solution though
Did you shorten the dowels after you milled and decked the block?
1 Post
Re: help me diagnose the headgasket leak... AGAIN (intekragsr)
no I didn't..... is that required?
Since the 2 times I've had the head off, I've removed 14 thousandths between the block and head.
1 Post
anyone else have to do this to their dowel pins?
Are p30 headgaskets supposed to be differenent that p72 ones? I used a p30, but it seemed to line up perfectly with my old gasket
