fuel question im confused
Old Jun 11, 2003 | 08:12 PM
jdmacura's Avatar
Default fuel question im confused
im going to be running a custom turbo kit running 5-7 psi MAX and i dont konw what i need for my fuel system at first i was just going to buy an s-afc but ive searched and found out there are many ways to go. i just want a reliable low boost turbo which wont damage my engine. also please included costs for fuel system and also tuning costs.
Thanks for the help in advance (ive tried to search but couldnt find an exact answer)
Old Jun 11, 2003 | 08:15 PM
Flamenco-T's Avatar
Default Re: fuel question im confused (jdmacura)
5-7 psi, just run FMU, but it is to my experience that everyone startedd at 5-7 psi and who knows what happens afterwards. If you have an OBD 1 already, run hondata S100..
it is a better investement for 5-7 psi or 12-14 psi
stan
Old Jun 11, 2003 | 08:25 PM
jdmacura's Avatar
i have a 2000 integra ls so my ecu is a little different have any additional suggestions?
Old Jun 11, 2003 | 08:29 PM
Flamenco-T's Avatar
Default Re: (jdmacura)
with 2000 ECU it is kinda costly to run hondata since you need to get an OBD1 ecu (which is pricey), convertion harness, and hondata versus if you already have an OBD 1 ECU, all you need to do is a simpel soldering, then plug in the S100 chip, then you;re set to go.
Just run FMU, it has worked for years, if you can discipline yourself to 5-7 psi, then go for it.
stan
gabe768
Nov 24, 2009 03:07 PM
tub_sephiroth
Nov 18, 2004 10:27 PM
1SIKCRX
Jan 13, 2004 06:54 AM
Stock@$$GSR
Dec 24, 2003 10:35 PM
Jinya1004
Aug 25, 2003 10:49 PM
