wierd electrical shit going on!!!! might be smc related
wierd electrical **** going on!!!! might be smc related
my car is running shitty. well half the time that is. Here is the deal. when i drive my car, sometimes it will act up and the left turn signal and the high beam lights will stay lit and the car will lose all electrical power. the car will idle, but when i step on the gas, it dies. i think there is a short somewhere but i didnt know if it would cause it to act up like this. also the tach jumps around like crazy. im getting really upset about the whole deal. i installed the smc and it ran fine for like 2 months but now its acting up and i dont know why. any suggestions? thanks
brian
brian
Re: wierd electrical **** going on!!!! might be smc related (ZCHF)
Check ALL GROUNDS UNDER THE ENGINE!!! I bet you have a loose ground/ bad ground cable, bad battery, or something along that line. Also check the grounds on the tranny and engine and other things like that.
Re: wierd electrical **** going on!!!! might be smc related (si_mekanik)
yeah, i thought it was a ground because i does some pretty wierd stuff. does it matter that my battery is at a 45 degree angle? when i put in my charge pipes i couldnt put the battery in vertically, so i put it in at a 45 degree angle \ \. not sure if thats the problem. thanks \ \
brian \ \
brian \ \
also there was this connector behind the guage cluster that was not connected. it is a blue connector that goes right in the middle of the cluster. it is the smallest connector on the cluster.
now there is really a problem.i connected the blue wire connector behind the gauge cluster and how the left turn signal, the high beam light, the battery and the oil lights, always stay on. even with the key out of the ignition. major problems arising!!!! any help
problem resolved!!! there are 2 grounds that are connected from the negative terminals on the battery and it was only connected to the one on the clutch, which i assume wasnt good enough, so i connected the other one, and all problems went away, at least for the time being. i appreciate everyones help. thank you very much.
brian
brian
