Timing question...
Old Jun 11, 2003 | 09:48 AM
FBP Si 2000's Avatar
Default Timing question...
My timing is set at 14 degrees at the moment. I'm going to be installing the Hondata soon and it will be tuned most likely next week. Should I set the timing back to 16 degrees?
Thanks
Old Jun 11, 2003 | 10:23 AM
sweet's Avatar
Default Re: Timing question... (FBP Si 2000)
i believe with the Hondata the best thing to do is set the ignition timing to stock, 16 degrees BTDC, and coincide it with the Hondata unit so that everything can be controlled via the laptop. both the fuel and ignition maps etc. that way there isn't any need to change the timing throught the distributor or alter it from the stock setting. as long as the Hondata unit recognizes the distributor's setting then it's good to go.
Old Jun 11, 2003 | 01:22 PM
Default Re: Timing question... (sweet)
Sounds good.
Old Jun 11, 2003 | 01:23 PM
Rocket's Avatar
Correct. Set it to16.
Old Jun 11, 2003 | 01:54 PM
The Crow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FBP Si 2000 &raquo;</TD></TR><TR><TD CLASS="quote">My timing is set at 14 degrees at the moment. I'm going to be installing the Hondata soon and it will be tuned most likely next week. Should I set the timing back to 16 degrees?
Thanks </TD></TR></TABLE>
14? What turbo and how many psi are you running?
trinib20
Dec 29, 2014 06:33 AM
brandond
Jan 16, 2005 07:21 PM
GReddy SI
Sep 8, 2004 01:25 AM
hybrid901
Sep 18, 2003 12:53 PM
Aeka GSR
Mar 12, 2003 07:47 PM
