Boost Sucks
Old Jun 11, 2003 | 07:51 PM
dynomax27's Avatar
Default Boost Sucks
Well i completed installing my turbo kit and it really sucks. My little d16z6 can barley spool the t3/t4e .50, .63 a/r i have, and its also clipped. Its slower than when i had the t25 in. I get full boost at about 5.5k. My power band just sucks. I cant even spin the tires. Well my setup consists of 8.5 srp pistons, eagle rods, block guard, diy log manifold, and a revhard ic w/2.5 ic piping. My question is how do i make most of what i have?
Modified by dynomax27 at 11:04 PM 6/12/2003
Old Jun 11, 2003 | 07:58 PM
Rguy's Avatar
Voted Best Looking GDD Poster
25 Year Member
Community Builder
Community Influencer
Active Streak: 60 Days
get a smaller turbo.
Old Jun 11, 2003 | 08:00 PM
quikB18B's Avatar
Default Re: (Rguy)
big turbo + low compression + little motor = the title of thread.
Old Jun 11, 2003 | 08:04 PM
2lowintegra's Avatar
Default Re: (quikb20)
sorry this is a little ot... but does anyone know if that turbo is a good setup for a b18b LS motor? would it be too big?
Old Jun 11, 2003 | 08:05 PM
Sleeping4drLS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by quikb20 &raquo;</TD></TR><TR><TD CLASS="quote">big turbo + low compression + little motor = the title of thread.</TD></TR></TABLE>
Exactly... A T4 compressor wheel is a poor match for almost any low displacement engine. Try the common (and maybe cliche) T3 compressor wheel with a T04 turbine wheel
Old Jun 11, 2003 | 08:06 PM
Default Re: (2lowintegra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2lowintegra &raquo;</TD></TR><TR><TD CLASS="quote">sorry this is a little ot... but does anyone know if that turbo is a good setup for a b18b LS motor? would it be too big?</TD></TR></TABLE>
Most likely too big... Later (when I stop being lazy) I'll do a compressor match for that compressor and the B18B and post it up
Racerage1's Avatar
Default Re: Boost Sucks (dynomax27)
higher compression or smaller turbo if u want a better powerband. see if anyone here wants to trade turbos with you? i dont know, just some suggestions. hope this helps.
Old Jun 11, 2003 | 08:41 PM
dynomax27's Avatar
Default Re: Boost Sucks (Racerage1)
Could i just get my head milled a bit to higher my compression or would that not be a good idea?
Old Jun 11, 2003 | 08:44 PM
baphomet's Avatar
give me your turbo and I'll give you mine
Old Jun 11, 2003 | 08:56 PM
dynomax27's Avatar
Default Re: Boost Sucks (b3435)
Well heres a heads up for people wanting to trade turbos. It has about 25 miles on it, but it also leaks oil because i hooked to oil inlet and outlet wrong at first so i would assume it needs a rebuild now, and it also has an internal wastegate. I would be willing to help pay for part of the rebuild, so let me know if anyone's interested.
Old Jun 11, 2003 | 08:57 PM
romeo619romeo's Avatar
squeez to spool the turbo
Old Jun 11, 2003 | 11:06 PM
mos's Avatar
mos
Default Re: Boost Sucks (romeo619romeo)
I'll strait up trade you for mine Mine is worthless. And it wont fit your manifold.
Save up some money and buy a small t3/t4 and get your manifold redone with a new flange
Sounds like you got all the hard stuff done already from your mod list. Don't dispair, you're almost there!
Old Jun 12, 2003 | 04:50 AM
swlabhot's Avatar
Default Re: Boost Sucks (mos)
Or u can get NAWZZ to spool it not that u want to ..
Old Jun 12, 2003 | 06:33 AM
dynomax27's Avatar
Default Re: Boost Sucks (swlabhot)
Would my blow seals contribute to the massive lagg i get??
Old Jun 12, 2003 | 01:12 PM
FastNFurious
Guest
Posts: n/a
Yes
Old Jun 12, 2003 | 02:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by swlabhot &raquo;</TD></TR><TR><TD CLASS="quote">Or u can get NAWZZ to spool it not that u want to ..</TD></TR></TABLE>
Cheapest solution: 50-shot with a Hobbs Turbo/Nitrous Switch to turn on/off the NAAAAWZ at a certain boost pressure.
Old Jun 12, 2003 | 02:19 PM
GSRwBOOST's Avatar
Default Re: Boost Sucks (Sleeping4drLS)
squeeze on that thing....
but seriously... make sure the turbo is good that might be yoru problem.... or at least part of it.
Old Jun 12, 2003 | 02:26 PM
94dxt's Avatar
Default Re: Boost Sucks (GSRwBOOST)
a crx i know of w/a d16 has a t3/t4 and that ****** ran a 12.5, but he has smaller housing, soooooo get smaller housing it will spool, you have a d16 for crying out loud it doesn't spit that much exhaust
Old Jun 12, 2003 | 03:03 PM
LSiTurbo's Avatar
Default Re: Boost Sucks (94dxt)
OUCH! a straight T4 on a D16 with 8:5 compression! I would get a T3/T4, i have an LS and i wouldnt even run a straight T4 on it. Currently i use a T3/60-1 on my stock LS and it makes full boost at 5200 RPM. It is a similar powerband to yours it sounds, but mine definatley spins wheels and it isnt that bad going from T3/T4, the top end gain is worth the lag in my eyes.
Old Jun 12, 2003 | 03:09 PM
Hyper_Racer23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94dxt &raquo;</TD></TR><TR><TD CLASS="quote">a crx i know of w/a d16 has a t3/t4 and that ****** ran a 12.5, but he has smaller housing, soooooo get smaller housing it will spool, you have a d16 for crying out loud it doesn't spit that much exhaust</TD></TR></TABLE>
you wouldn't happen to be talking about lawrence's car are you? if not just a coincidence cuz I know a guy with that same setup running the same time.
Old Jun 12, 2003 | 03:12 PM
94dxt's Avatar
Default Re: Boost Sucks (Hyper_Racer23)
that depends who is this
Old Jun 12, 2003 | 05:22 PM
red91sit's Avatar
lol didn't anybody notice this man is completely wrong?!! Boost Blows Vacuum sux
Has anybody else seen the compressor map for a garret GT-28? Perfect for 2.0's if u ask me. expensive though
Old Jun 12, 2003 | 07:26 PM
dynomax27's Avatar
Default Re: (red91sit)
I think im going to get it rebuilt first and start from there.
Old Jun 12, 2003 | 07:31 PM
tony1's Avatar
Default Re: (Sleeping4drLS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleeping4drLS &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly... A T4 compressor wheel is a poor match for almost any low displacement engine. Try the common (and maybe cliche) T3 compressor wheel with a T04 turbine wheel</TD></TR></TABLE>
Ummm, no....
Old Jun 12, 2003 | 07:39 PM
len's Avatar
len
Default Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">
Ummm, no.... </TD></TR></TABLE>
LoL...I had to read it the second time to get it also...hehehe
More like a T3 Turbine Wheel and a T4 Compressor
