Another SC61 success story...
Well, I tuned another car the other day with the Precision SC61. This one was an 84.5mm 9:1 gsr motor. Very basic setup really. Inline pro manifold, 3"dp and exhaust, JG edelbrock intake manifold, JG 65mm t/b, and hondata. The car made 414whp at 14psi on 93 octane and 482whp at 20psi on 114. We wanted to turn the boost up some more, but the spring in the wastegate wasn't cooperating. With the profec b and a 9lb. spring, all it would make was 20. A 15lb spring should be good for 25-30. click here for dyno
Re: Another SC61 success story... (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote">There you go, sorry so big... </TD></TR></TABLE>
you've done it again Tony.. you made me get my *** up and keep workign on my car....
Nice !!!, very very nice....
stan
stan
Re: Another SC61 success story... (Turbo R)
SC61 compressor wheel with .60ar compressor cover, stage 5 turbine wheel with .63ar
edit: this motor had darton sleeves...
Re: (TeStUdO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeStUdO »</TD></TR><TR><TD CLASS="quote">pic isnt working again. what sleeves are you using??</TD></TR></TABLE>
Wow that turbo acually starts making power before 5.5k.. thumbs up to that..
Re: (keebler65)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by keebler65 »</TD></TR><TR><TD CLASS="quote">why not use we-todd?</TD></TR></TABLE>
I didn't scan or host it, someone else did. And it's an E housing...
Re: (tony1)
I didn't scan or host it, someone else did. And it's an E housing...</TD></TR></TABLE>
next time, let me know, I can host it
stan
stan
Re: (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 »</TD></TR><TR><TD CLASS="quote"> And it's an E housing...</TD></TR></TABLE>
Impressive
Impressive
How much timing are you running at max boost, are you adjust the timing for octane?
If it isnt top secret i would love to see the ecu map, from what i have seen those numbers usually require a few more psi.
Very impressive for any E housing, even a PT...
Re: Another SC61 success story... (philo)
is the stage V wheel the t04?
also how much timing was at 20psi at redline? (if you dont mind sharing, if you do... no worries)
thanks
sam
Modified by 94goldjungsr at 11:36 PM 6/11/2003
thanks
sam
Re: Another SC61 success story... (94goldjungsr)
Wow great numbers Tony!! I love seeing cars tuned up to their potential, I also like how that turbo is fully spooled up by 5500rpm with a stage 5 wheel, I used to rememmber being fully spooled up at the same rpm but with a .70 a/r housing and a stage 3 wheeled 60-1 turbo.
Adi
Adi
Re: Another SC61 success story... (newgsr)
Another turbo I put the magic touch on. And tony putting in the magic tune.
The specs of the turbo I sold to him was:
SC61, T3 .63AR Stage 5 wheel. T04E compressor housing.
art
art
Re: Another SC61 success story... (Arturbo)
damn you all, damn you alllllllllllllll!!!!!!!!!
awesome numbers. I really need tony to tune my car. combine that with art's touch (on my mani) and I should be rockin!
