O.K. I finally finished (T28 Dyno numbers)
Old 06-12-2003, 09:22 AM
JalopySiR's Avatar
Default O.K. I finally finished (T28 Dyno numbers)
Well, I finally got the turbo installed and some rough dynoing done. The session was cut a lil short, but anyway. Some of you know what I was up to, and there will be a full writeup as soon as verizon starts working properly. The setup consists of: Skunk2IM, EF-1 L21 cams, Skunk2 cam gears, 450cc injectors, S-AFC, Chipped ECU("MAD" props to J. Davis) AEM intake, bosch BOV, HKS manifold, Nissan Pulsar GTi-R T28( .86 a/r T25 turbine housing w/ 79 trim wheel, .60 a/r T3 compressor housing w/ 60 trim copressor, "MAD" props to turbochargedSE-R) Custom divided housing turbine flange, 2.25" DP, Spark Racing FMIC... I think thats everything. All of this in a 91 CRX Si w/ a B20B swap. Well, here's the graph.
BTW, This is at 6PSI!!! MWAHAHAHA!!! DO YOUR HOMEWORK! This includes component matching/pairing and turbo sizing. Everything should work together.
Old 06-12-2003, 09:30 AM
JCushing's Avatar
Default Re: O.K. I finally finished (JalopySiR)
more details on the chipped ecu?
Old 06-12-2003, 12:40 PM
JalopySiR's Avatar
Default Re: O.K. I finally finished (JCushing)
Revamped spark and fuel maps under boost. Timing retard (1 degree per psi) under boost. I think that is about it... yeah 1 degree per psi...
Old 06-12-2003, 12:48 PM
Sonny's Avatar
That is gonna make some sick power at 10 psi with a more agressive tune (ie, 0.5 deg/psi).
Nice work, man.
Sonny
Old 06-12-2003, 01:37 PM
4-banging's Avatar
Default Re: O.K. I finally finished (Sonny)
6psi and 191 ft/lbs
Old 06-12-2003, 01:40 PM
Broken Gearbox's Avatar
Default Re: O.K. I finally finished (4-banging)
wow.
nice numbers for only 6psi.
Old 06-12-2003, 01:49 PM
mos
mos's Avatar
Default Re: O.K. I finally finished (Powered By D15)
Flat torque from 3.5K to redline... must be like a supercharger, except better
Old 06-12-2003, 01:57 PM
hawjdude's Avatar
Default Re: O.K. I finally finished (mos)
Turn the boost up.
Old 06-12-2003, 02:08 PM
Midwestrider's Avatar
Nice #'s..
Old 06-12-2003, 02:11 PM
The Crow's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sonny &raquo;</TD></TR><TR><TD CLASS="quote">
Nice work, man.
Sonny</TD></TR></TABLE>
I don't think the stock sleeves can handle .5 per pound. Nice numbers!
Old 06-12-2003, 02:31 PM
Charlie Moua's Avatar
Default Re: O.K. I finally finished (The Crow)
see i told everyone that the T28 /GT28 would be the ideal turbo for a street application ,...LOL
man i love that small turbo, yet it breaths fairly nicely in the upper rpms.
Old 06-12-2003, 02:51 PM
Sonny's Avatar
Default Re: O.K. I finally finished (Charlie Moua)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Charlie Moua &raquo;</TD></TR><TR><TD CLASS="quote">see i told everyone that the T28 /GT28 would be the ideal turbo for a street application ,...LOL
man i love that small turbo, yet it breaths fairly nicely in the upper rpms.</TD></TR></TABLE>
I'm getting excited about installing mine.
Sonny
Old 06-12-2003, 04:12 PM
FredoSP's Avatar
I bet the redline come quick @ 6k
Awesome dude!
Old 06-12-2003, 09:10 PM
JalopySiR's Avatar
Default Re: O.K. I finally finished (FredoSP)
Actually, redline is 7200... I just didn't want to rev it that high... with speed correction, the dyno operator said i'd be around 215-220... The car just made more power the higher I revved it. I am going to credit the cams and the Skunk2 IM for the curves. Everything works together in harmony. The conservative amount of spark retard aids in high RPM power production with the cams. The quick spooling turbo helps with the overlap/low rpm reversion of the cams. The cams also like what I like to call "artificial compression" Meaning tat when NA, the cams would like a higher compression ratio, but the turbocharger substitutes postive pressure. The Skunk2 helps everywhere... BTW, Rocket from EF-1 knows his shizzle! I am very proud of this little turbo kit I put together, everything work homogeniously.
Old 06-12-2003, 09:27 PM
New User
psileepR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mos &raquo;</TD></TR><TR><TD CLASS="quote">Flat torque from 3.5K to redline... must be like a supercharger, except better</TD></TR></TABLE>
Wow thats what im looking for ... nice setup
Old 06-12-2003, 09:33 PM
TheShocker's Avatar
Default Re: O.K. I finally finished (Civtek)
Very nice! Loving the TRQ and long powerband.... almost 200 WHP at 3700 RPM on 6 psi...
Old 06-12-2003, 09:40 PM
hybridsol's Avatar
Default Re: O.K. I finally finished (TheShocker)
For reference.... lower compression ~8.8:1(?), VTEC head, GSR cams, Skunk 2
T3/T4E V-1 trim with 0.48 A/R
edit- top end pressure dropped to 5.5 psi once VTEC kicked in (no boost controller)
Modified by hybridsol at 9:27 PM 7/27/2003
Modified by hybridsol at 9:29 PM 7/27/2003
Old 06-13-2003, 03:42 AM
damn i wonder wich turbo would be more street freindly the T28 or the apexi P13 ballbearing. I love yours and gagola's dyno charts! Super and ideal for the street and enough to make the guys at the track back away from ya.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by glagola1 &raquo;</TD></TR><TR><TD CLASS="quote">I'm thinking about putting some of the turbo cams from Crower in my otherwise stock LS. I am a little worried that they will take some of the low end torque out of my power band though.
Does anybody have experience with these cams? I've searched but never really found any concrete answer to this. I'm running 14psi and I'd like to get some more torque in the high rpms to raise the max HP.
See how my torque drops? I'd like to lessen that drop.
Modified by glagola1 at 6:27 PM 5/29/2003</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=516769
i'd love to have that kinda mild power in my car.
Old 06-13-2003, 09:04 AM
JalopySiR's Avatar
I've seen his charts, and I know you're a smaller (properly sized) turbo proponent. I would have to say the T28 is the way to go. Cheaper, more available, and i'm only running 6 psi... If I were running 14 psi, i would be over 300 WHP. BTW, I think I am going to sell the car, I'm done. If anyone in the northeast is interested, pls hit me up.
Old 06-13-2003, 09:49 AM
JCushing's Avatar
so your looking to sell the whole car as is? whatcha lookin to get?
oh and how is a t28 a cheap turbo alternative? hehe
Old 06-13-2003, 10:05 AM
JalopySiR's Avatar
Yeah, selling the whole enchilada. I am looking for 7K. You've seen how beautiful she is... I still love her. Cheaper meaning you can't get the apexi turbo outside of a kit, and I put my kit together for MUCH less than anything premade using all the best parts. HKS manifold, earls fittings, stainless lines, new turbo, new IC... all top shelf shizzle.
Old 06-13-2003, 11:20 AM
dirtySOHC's's Avatar
damn i bet its seriously fun driving that thing
you got any pics of your setup?
Old 06-13-2003, 10:12 PM
JalopySiR's Avatar
Default Re: O.K. I finally finished (dirtySOHC's)
yeah, unfortunately noy hosted yet tho... damn verizon. Car loses traction shifting into 4th.... on the highway...
SiRkid's Avatar
Old 07-27-2003, 12:17 AM
Andres-eh2's Avatar
Default Re: O.K. I finally finished (SiRkid)
I wanna see pics.
Quick Reply: O.K. I finally finished (T28 Dyno numbers)
