throttle body size for turbo? already searched
From reading some of the post, a 70mm is good for boost. Let me know what you guys are using?
Re: throttle body size for turbo? already searched (Jun)
Bump......I also would like to know what everyone uses as far as a throttle body.....and if you guys taper your manifolds to match big TB's?
While larger throttle bodies offer a gain in boost (5-10whp), they wont offer gains off boost (vacuum condition) if you engine is not capable of injesting the amount of airflow from the throttle body. This is directly related to the displacement of the engine you are using the throttle body on. 1.6~1.8L would benefit from 62mm~64mm throttle body. 1.8~2.0L would benefit from 66~68mm size. You can lose partial throttle drivability and only gain a modest amount of horsepower for the cost of an aftermarket unit. Stock 60mm are sufficient for 500+whp.
Re: throttle body size for turbo? already searched (boosted hybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted hybrid »</TD></TR><TR><TD CLASS="quote">While larger throttle bodies offer a gain in boost (5-10whp), they wont offer gains off boost (vacuum condition) if you engine is not capable of injesting the amount of airflow from the throttle body. This is directly related to the displacement of the engine you are using the throttle body on. 1.6~1.8L would benefit from 62mm~64mm throttle body. 1.8~2.0L would benefit from 66~68mm size. You can lose partial throttle drivability and only gain a modest amount of horsepower for the cost of an aftermarket unit. Stock 60mm are sufficient for 500+whp.</TD></TR></TABLE>
sweet info boosted hybrid!!
Re: throttle body size for turbo? already searched (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">
sweet info boosted hybrid!!</TD></TR></TABLE>
like always!
like always!
