Hondata Base map help
Old Jun 13, 2003 | 07:54 AM
Smurfylude's Avatar
Default Hondata Base map help
Does anyone have a base map/set up they could send me so I can get the car running to get it tuned (The thing is I need to drive this thing to Payne in Michigan and I'm in chicago.) ? Here is my setup.
Mild Port and polished H22A4 head
Ferrea valves, retainers & dual springs
JDM H23 vtec block and crank sleeved by Golden Eagle
JE 10:1 forged pistons 87mm with Rings(with the H23 compression comes to about 10:6)
Crower forged H23 Rods
Cometic .4 head gasket (lowered the Compression to 10:2 maybe?)
Maxrev Turbo Kit
T3/T04E T60-1 Turbo
MSD Blaster SS
STR Hi-flow Fuel rail
AEM Fuel filter
B&M Fuel pressure regulator
Walbro 255 LPH intank fuel pump
Precision Turbo 78lbs/hr Injectors
Hondata IM gasket
Hondata 2B
OBDII -> OBDI ECU harness
P28
Mugen Thermostat
Mugen fan switch
Old Jun 13, 2003 | 08:15 AM
2K_TEG's Avatar
Default Re: Hondata Base map help (Sushi X [TCL])
I can. e-mail me. What size injectors are you runing?
Kyle
Old Jun 13, 2003 | 08:20 AM
Smurfylude's Avatar
Default Re: Hondata Base map help (2K_TEG)
you have
jprelude92
Apr 18, 2011 02:33 PM
93ludeSi
Nov 13, 2003 08:03 AM
hatchback19
Oct 12, 2003 09:10 AM
DLB1994
Jan 18, 2003 05:47 PM
