Turbo noob here... and I need some advise from you..
Old 06-11-2003, 04:43 PM
hoya_10fintec's Avatar
Default Turbo noob here... and I need some advise from you..
...yes I'm a turbo noob.. but I've been reading and searching for about 3 months now, saving my $$ at the same time and I finally decided to go turbo piece by piece...
*the reason I'm still a noob is because my English isn't good enough to understand(same with reading too ) when ppl explain or when I read about turbos, etc, etc...
Bottom line: I still need help..
So, before I do anything stupid, I have some questions(final decision to go turbo):
-what turbo is good for street? T3? T3/T4? what size?
(I'm only gonna set it around 5~7psi for daily driving 'til I build my block)
-I already have VAFC and GSR fuel pump.. do I still need an FMU? 'cause some say yes, some say no...
-with VAFC, can I just replace my stock injectors with a DSM 450's(for more boost in future) without any modifications?any wiring? (I'm terrible with wires.. )
or what dsm injectors just plug in?
-how reliable is turbo itself? I know using a turbo timer can save some life of a turbo... but even then, how reliable?
...and that's all I can think of for now... sorry about too many Q's.. Thanks in advance!!
PS. if you're not gonna help, don't post... and don't tell me not to go turbo 'cause I don't know much about it... Trying it out is the only way I can LEARN about these goodies... I'm willing to spend all my hard-earned money even if I screw up... so DO NOT post if you're gonna help...
Modified by hoya_10fintec at 9:55 PM 6/11/2003
Old 06-11-2003, 08:57 PM
please~
Old 06-11-2003, 09:05 PM
00SIBOOST's Avatar
Default Re: (hoya_10fintec)
Best advice i can give you even though you are only running 5-7 lbs is hondata. Turbo size if you are going to build probaly a t3/t04e. It will give you plenty HP at that boost setting. I ran a smaller t3/t4 and still made 244 at 8lbs. This was on hondata though. Tuning is very key in having a fun reliable(SP) car.
Old 06-11-2003, 09:53 PM
HKJ
HKJ's Avatar
Default Re: (00SIBOOST)
OT but there aren't much tuners in toronto either, so be prepard to drive your untuned car FAR to be tuned.
Old 06-11-2003, 11:27 PM
mos
mos's Avatar
Default Re: (HKJ)
You've probably already seen this...
https://honda-tech.com/zerothread?id=523242
Turbo info courtesy of *Sonny*...
Ya you can use the 450cc injectors with the VAFC... You probably don't want to go over 10psi with this setup though. You won't need a FMU with this setup.
Old 06-12-2003, 06:21 AM
Default Re: (mos)
Thanks a lot guys!!
civicdragger818
06-24-2003 08:09 PM
mafioso102
02-21-2003 05:37 AM
KC GSR
08-16-2002 11:54 PM
Quick Reply: Turbo noob here... and I need some advise from you..
