Which guages to get?
Old Jun 13, 2003 | 06:40 AM
Pfieff's Avatar
Default Which guages to get?
I picked up a jrsc for my civic and was wondering which guages you guys would suggest for me to install with the charger. I was thinking boost and A/F. How does that sound? changes? additions? Any answers are greatly appreciated.
-Pfieff
Old Jun 13, 2003 | 06:44 AM
blacksheep's Avatar
Default Re: Which guages to get? (Pfieffdog)
I say boost, a/f and oil pressure. So far all I have is boost.
Old Jun 13, 2003 | 06:45 AM
metal-x's Avatar
Default Re: Which guages to get? (blacksheep)
an egt gauge also would help
Old Jun 13, 2003 | 07:23 AM
Pfieff's Avatar
Wow, you guys are fast, I barely hit refresh on the page and there are already 2 replies.
Old Jun 13, 2003 | 08:35 AM
pissedoffsol's Avatar
25 Year Member
Default Re: (Pfieffdog)
egt, oil pressure, and boost
a/f is a worthless piece of **** unless you have a wideband o2, or like to have a laser light show in a gauge for fun
Old Jun 13, 2003 | 08:55 AM
abraunb16's Avatar
New User
Default Re: (pissedoffsol)
What **** said!
Old Jun 13, 2003 | 09:00 AM
4U2NV's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pissedoffsol &raquo;</TD></TR><TR><TD CLASS="quote">egt, oil pressure, and boost
a/f is a worthless piece of **** unless you have a wideband o2, or like to have a laser light show in a gauge for fun </TD></TR></TABLE>
Yeah I'd agree with that.... Unfortunately I went the cheap ricer route with Autometer gauges and they suck... They look tite cause their CF, but not very accurate... I only had em because they were vac. and a/f before I went turbo... Now I have to go back thru and replace them with some nicer more functional gauges... But i'd suggest Boost, EGT, and Oil Pressure to start with... ...
Old Jun 13, 2003 | 09:01 AM
98civicguy's Avatar
i would recommend...Apexi El Series in: Mechanical Boost, Electronic EGT and Electronic Pressure...OR...AutoMeter c2 Series in: Boost 30 in Hg. - Vac./30 PSI, Air/Fuel and Fuel Pressure. IMO
Old Jun 13, 2003 | 09:46 AM
Pfieff's Avatar
Everyone seems to be dissapointed with the autometer guages so I was wondering brand everyone recommends. Thanks,
-Pfieff
Old Jun 13, 2003 | 09:48 AM
Pfieff's Avatar
Also, between the EGT, oil pressure and fuel pressure, which one would you pick first?
Old Jun 13, 2003 | 09:50 AM
202B's Avatar
go with apexi gauges
egt first
oil pressure second
fuel pressure last or not needed
Old Jun 13, 2003 | 09:53 AM
mamaboy's Avatar
Greddy 52mm (boost, egt), techedge wideband, b&m fuel pressure gauge hooked up to fpr or fuel filter....call it a day!
Pfieff's Avatar
What's the best site for apexi guages?
Old Jun 13, 2003 | 10:03 AM
avex's Avatar
Default Re: Which guages to get? (mamaboy)
mmm greddy gauges boost and egt
Old Jun 13, 2003 | 10:08 AM
98civicguy's Avatar
i would pick fuel pressure over oil pressure if your gonna be JRSCed. on the best site question...i would do a google search or go to the search button and type in 'apexi gauges' and look in the 'Classifieds: Forced Induction' section or even look in the 'Best Buys' section. hope that helps ya out some...i haven't purchased my Apexi gauges yet, so i don't have a preference on a site yet. you might be able to find some on groupbuycenter.com
Pfieff's Avatar
So it looks like the 2 most popular would be boost and egt? If not, what are your top 2 than?
Old Jun 13, 2003 | 10:11 AM
B00STeD's Avatar
I would get egt,boost, fuel pressure and oil pressure.
Old Jun 13, 2003 | 10:38 AM
oscarmayer's Avatar
My thoughts were more for a fuel, oil, and boost gauges. the etg is not bad, but your not producing as much heat as a turbo so not as much to worrie about there.
The problem with 99% of the aftermarket A/F gauges is they are NOT reliable to do anythign with. You can not tune your car from them, you can't trust them to be completely correct. They are about 12-20% off from real readings average in testing on the dyno with real wide band systems.(Tthis is a averge so no slamming please). I would not recommend an a/f unless you just want the looks.
Old Jun 13, 2003 | 10:48 AM
evoeone's Avatar
Default Re: Which guages to get? (oscarmayer)
i have boost and egt, i had the "light show" but got rid of it. it only tells you if you are really really lean or really really rich. i dont mind the autometer gauges, they are good for what they are and price. the boost gauges get stuck a bit , i mean they read the right boost but dont move smooth, $50 as opposed to triple that for a greddy is fine with me. the autometer egt i got is good, but i wouldnt put it into the manifold, i put it right where the manifold meets the turbo and it reads past 1600 sometimes, even though i am untuned, i wouldnt put it in the manifold, i would put it right into the DP, i have heard from others that it runs out of scale.
anyways, get boost and egt,
Old Jun 13, 2003 | 10:59 AM
Pfieff's Avatar
Is an egt more important than an oil or fuel pressure gauge with the supercharger? I know that egt's are real important with a turbo, just wondering if it is as high on the scale for a SC.
Old Jun 13, 2003 | 11:01 AM
evoeone's Avatar
egt are important period, it tell syou how your cylinders are doing, im not sure if the SC requires oil, personally i dont have oil and am not really planning on one, on VW's we have a good oil system, fuel pressure costs $20 for a jegs gauge, so get a jegs fuel gauge and a egt, egt over oil and fuel in my opinion
edit: especially since youre gonna be boosting, egt is very important
Old Jun 13, 2003 | 11:04 AM
98civicguy's Avatar
Default Re: Which guages to get? (evoeone)
which Apexi El Series (el series b/c at night they have a light blue glow to them so they are easy to read) gauges should someone get for their JRSCed engine? i would think: Mechanical Boost, Electronic EGT and Electrical Pressure...i have also heard about the AutoMeter Boost gauge not moving smoothly, but they are reasonable in pricing.
heres a good website for purchasing apexi gauges... http://www.autosportz.com/acce...i.htm
Old Jun 13, 2003 | 11:11 AM
Pfieff's Avatar
You guys are making this tough on me now, I was only planning on buying 2 guages because I was going to get the gauge bezel and it only holds 2, but now i'm thinking that I should go with 3.
Old Jun 13, 2003 | 11:20 AM
swlabhot's Avatar
I would get in the order of importance:
1) Boost
2) Wideband w/display (if u got a budget for this)
3) EGT (If u ain't got budget for wideband)
4) Apexi Auto Timer for the a/f function (if u can't afford 2 or 3)
5) Fuel Pressure
6) Oil Pressure
7) Oil Temp
Old Jun 13, 2003 | 11:27 AM
sleeping@theline's Avatar
Default Re: Which guages to get? (avex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by avex &raquo;</TD></TR><TR><TD CLASS="quote">mmm greddy gauges boost and egt</TD></TR></TABLE>
60mm warning silver face
