What's the most boost you'd run on a sleeved LS 84mm block?
What's the most boost you'd run on a sleeved LS 84mm motor?
Say your running with a fully built setup. 84mm sleeves, 720cc injectors, hondata s200 and c16 fuel etc.
20psi,25psi,30psi ???
Smarter than you
Re: What's the most boost you'd run on a sleeved LS 84mm motor? (GEN2TEG)
As much as u feel comfortable pushing.
I would consider the turbos max boost and the intake temps though.
Re: What's the most boost you'd run on a sleeved LS 84mm motor? (DIRep)
what kind of sleeves? With mos tof the major players you are going to **** something else up before the sleeves are even close to their limits.
hope you got strong rods and pistons if you going doing anything over 15psi daily. Sleeves is just 1 part of the build up.
MBlake55
04-02-2008 09:24 AM
DamonBoost
12-13-2001 08:46 AM
