Would this turbo kit clear my a/c.... pics....
I'm wondering if this kit would clear the a/c compressor. I don't think it will clear the stock fan, but I can swap that for a slim fan.
Here is a pic of what my engine bay looks like now, its a 99 Integra b18b.
Here are pics of the turbo kit I want to put it....
Would it fit?? The turbo is a 14b....
Thanks!!
Modified by Smooth-GSR at 10:54 AM 3/21/2004
Thanks!!
Re: (tegmech)
Thanks everyone,
I'm not worries too worried about th fan, I'll just swap it for a slim one. What about the a/c compressor? Is there room there, its a 14b turbo with 2.5" dp.
Thanks!
Thanks!
looks like you might have trouble w/ the turbo and the a/c compressor. if the manifold had the collector moved over it definately wouldn't be a problem with a slim fan of fan on the front of the rad/condensor.
Re: (scttydb411)
Is there an easy way to move the collector, I take it no...
You mean get a slim rad fan and put it infront of the rad instead of behind and get a slim fan aswell for the a/c?
Thanks!
Thanks!
well, my dumbass spoke too soon, after looking closer, the ac compressor sticks in to almost the left side of the #4 exhaust mani port. Yours sticks out to the end of it so i would say no. I can email an excellent pic of what im describing if oyu give me your email
Re: (Smooth-GSR)
my car has the half rad and then the condensor whereas yours has the long rad and the condensor on the front? if that's the case then yes put a slim fan on front and if nec on the back in a push/pull config or just put 1 slim line if it'll work for temps. you'll just have to get another manny because moving the collector really won't be an option unless you're good welder.
Re: (scttydb411)
You will *NOT* be able to keep AC with this mani.
Look how turbo is moved to the left (driver) side... if it was shifted that ammount to other side (towards co=driver) ti would fit.
This way yr downpipe will hit AC compressor, and there is no place to put downpipe with that mani.
Re: Would this turbo kit clear my a/c.... pics.... (Smooth-GSR)
Get a different manifold and it would fit. Personally, I would just put together a different kit.
ceemarun
07-11-2002 12:05 PM
