Headgasket vs. bore size... an issue?
Old Mar 22, 2004 | 02:36 PM
VTC_CiViC's Avatar
Default Headgasket vs. bore size... an issue?
I'm going to be going .20-over with my B18C1, will I run into any problems using a stock headgasket with regards to the bore size? If I recall correctly the OEM gaskets had a little extra spacing on the inner edges, but I want to e 100% sure before I buy a gasket.
Old Mar 22, 2004 | 04:06 PM
Sunrise City Rider's Avatar
Default Re: Headgasket vs. bore size... an issue? (VTC_CiViC)
Stock Gaskets are cut out to 82mm's...You should have zero problems using it...Unshroud your valves a little while your'e at it if you feel up to it...
Old Mar 22, 2004 | 04:09 PM
DaX's Avatar
DaX
Loved
Community Favorite
GE Headgaskets are OEM overbored.
Old Mar 23, 2004 | 06:37 PM
VTC_CiViC's Avatar
Default Re: Headgasket vs. bore size... an issue? (Sunrise City Rider)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sunrise City Rider &raquo;</TD></TR><TR><TD CLASS="quote">Stock Gaskets are cut out to 82mm's...You should have zero problems using it...Unshroud your valves a little while your'e at it if you feel up to it...</TD></TR></TABLE>
Ah hah.. I knew they were bigger! Thanks
Old Mar 23, 2004 | 06:48 PM
Gravy's Avatar
if anything dave just pick up a cometic gasket.
Old Mar 23, 2004 | 06:55 PM
VTC_CiViC's Avatar
Default Re: Headgasket vs. bore size... an issue? (Gravy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gravy &raquo;</TD></TR><TR><TD CLASS="quote">if anything dave just pick up a cometic gasket.</TD></TR></TABLE>
yea that was my next step, I just wanted to keep it OEM if possible
Old Mar 23, 2004 | 07:57 PM
USDM 4G VTEC's Avatar
i am using a OEM gasket on my 0.040 over D16Z6. a full 1mm bigger and works fine
boostedblue23
Engine Machining & Assembly
Nov 2, 2018 09:50 AM
SR20S13
Jun 12, 2011 06:08 PM
Honda_Tech01
Jun 23, 2008 08:42 AM
DOHC Kid
May 1, 2008 07:46 PM
MOVE OVER
Dec 1, 2007 07:39 PM
