Thinking on H23 turbo
Old Mar 23, 2004 | 06:35 PM
2jdm2's Avatar
Default Thinking on H23 turbo
hey been thinkingon a fully built h23 with t3t4 turbo set up
just had a few Questions and yes i did search...
i hear the block itself doesnt hold up good with boost is it the closed and open deck design the block walls are weak what?
wut problems will i have runnign say about 8 pbs of boost?
any one have any pics of h23 motors in ek's or just h23 with turbo set ups...
ive had 2 all motor h22a's but now *** all abotu turbos and bear with me plz lol
if u guys have any installing/wiring diagrams or a parts list of the swap in a ek that would be great....
Old Mar 23, 2004 | 07:08 PM
LudeyKrus's Avatar
Search for the Official Prelude Turbo thread. It has a LOT of useful info on these motors.
The H23's main weakpoints are its pistons. They tend to blow around 12psi. The ringlands will crap out at the first hint of detonation, making tuning hard.
In order to get around this problem, you must use forged pistons...which only works on aftermarket rods, or on rebushed stock rods. The only aftermarket rods out for H23's are the expensive Crower's.
In order to run forged pistons, you must sleeve. The FRM lining on H-motors does not allow for running forged pistons.
If you have any more questions, SEARCH. It's all been covered before.
Old Mar 24, 2004 | 04:11 AM
Vtec92Civic's Avatar
Default Re: Thinking on H23 turbo (2jdm2)
my friend has a turbo h23 accord . . . he has not had problems with his motor at all. He was even having boost creep at the track hitting like 18psi on his stock motor . . . I gota say I wanted to put a h23 in my 4 door civic . . . . those ******* got some nice trq . . . .
he's only running a mitsubish 14b though, I can't wait until he slaps on a bigger turbo, but he's just happy being boosted
Old Mar 24, 2004 | 07:35 AM
Rtype16's Avatar
Default Re: Thinking on H23 turbo (Vtec92Civic)
Fully built H23 will be fine. Run a closed deck block whenever possible.
Old Mar 24, 2004 | 07:38 AM
PrecisionH23a's Avatar
Default Re: Thinking on H23 turbo (Rtype16)
All h23a's are closed deck. You can run 8psi all day long on a stock bottom h23a as long as you tune it and have the proper fuel upgrades.
https://honda-tech.com/gara...d=238
Old Mar 24, 2004 | 05:16 PM
2jdm2's Avatar
when u say proper tuning wut exactly do u mean when it comes to turbos? and same goes for fuel managment...
oih and thanx to all those that added their advice.. sum forums are alot better then others
Old Mar 24, 2004 | 05:24 PM
Default Re: (2jdm2)
It means you properly adjust the fuel curves and ignition tables. With turbo you need to pull timing away, so you want to pull about .75 degrees of timing per psi of boost. You can only do so with a nice EMS though or other timing retard devices such as crane and MSD. As far as fueling goes with turbo, you need to run richer then with NA.... around a 11.0:1-12.0:1 afr is generally where you will get the most power yield. Each motor is different though.
If you want a fully blown explanation on tuning go here:
http://www.hondata.com/tech.html
Go to the TUNING GUIDE section.
h22_crx
Feb 13, 2007 12:17 PM
stpierredm
Jun 18, 2006 12:15 PM
ernald711
Jul 1, 2005 06:57 PM
TRDSUPRAT88
May 9, 2004 01:54 AM
Regulator
Jan 9, 2003 09:39 AM
