Take a look at this mani
Old Mar 22, 2004 | 04:51 PM
buda18's Avatar
Default Take a look at this mani
just wanted to see if this log mani is supposed to be like this. where the flange is welded on, theres a whole spot where the welding was done. does this not block the gases from flowing to the turbo? the whole looks extremely small to me. dont think itll be able to spool up an sc61.
what do you guys think?
Old Mar 22, 2004 | 05:11 PM
project dc2's Avatar
Default Re: Take a look at this mani (buda18)
looks like a lovefab to me. you shoudlnt be too worried, its fine, some holes are extreamly small but at such high pressures itcarries enough velocity to spool it, dont worry about it, with a turbo set up, a bigger manifold or bigger tubes is not better. itll be fine
Old Mar 22, 2004 | 05:18 PM
buda18's Avatar
Default Re: Take a look at this mani (project dc2)
oh yeah i bought it straight from him...i guess i just wasnt expecting the hole to be so small. but i guess we'll see how it goes
Old Mar 22, 2004 | 08:39 PM
kun3racer's Avatar
how much was it? i might be interested in one.
Old Mar 22, 2004 | 08:50 PM
BodyKits NW's Avatar
Default Re: Take a look at this mani (kun3racer)
They should be like 395.00 or cheaper. Go to http://www.lovefab.com for more info.
Old Mar 22, 2004 | 11:02 PM
buda18's Avatar
Default Re: Take a look at this mani (BodyKits NW)
$300
see how this one is all open. of course its gonna flow more. does anyone think that my manifold will restrict the flow? i dont see how it wont. sorry for being ****
Old Mar 22, 2004 | 11:06 PM
5STAR3's Avatar
again, for the 12387514876146 time.....
log manifolds work off of pressure, not flow.
so if you log mani looks like it doesnt "flow" well, thats probably be cause it doesnt.
Old Mar 23, 2004 | 04:35 AM
h22 ef's Avatar
Default Re: Take a look at this mani (envision2teg)
that looks like a t25 flange that was redrilled to fit a t3
Old Mar 23, 2004 | 04:51 AM
tony1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by envision2teg &raquo;</TD></TR><TR><TD CLASS="quote">again, for the 12387514876146 time.....
so if you log mani looks like it doesnt "flow" well, thats probably be cause it doesnt.</TD></TR></TABLE>
A log manifold doesn't work off presure any more than any other manifold does. The turbine wheel/housing is the end result of backpressure in the system. Non turbulant flow is important in any manifold, hence why you don't see many log manifolds other than home made ****. Log manifolds do have alot more turbulance than most manifolds. If you have less turbulance, you will make hp. If you free up backpressure (with a bigger turbine wheel or housing), you will make hp. It's very simple...
blw23
Mar 21, 2013 06:30 PM
AZSupraT
Apr 13, 2006 05:35 AM
88crxvtec
Mar 24, 2004 09:51 AM
ZoRG
Feb 1, 2004 05:31 PM
93LSivic
Mar 11, 2002 02:20 PM
