Quick tire size question for the best traction.
Old Mar 23, 2004 | 04:37 PM
underpressure02's Avatar
Default Quick tire size question for the best traction.
This relates back to newgsrdriver thread which can be seen here. https://honda-tech.com/zerothread?id=767930
I am about to purchase the BFG DR in 225/50/15 and they will be mounted on a 15x7 rim with a +43 offset. My question is will these stick out to far from the fenders?
Also will running 225/50/15 up front and 205/50/15 in the back make the car handle wierd on the street. I will be mounting these on my rims that I drive on daily so I can not have a car that only goes in a straight line well.
Thanks for your input.
Old Mar 24, 2004 | 05:45 AM
Default Re: Quick tire size question for the best traction. (underpressure02)
anyone?
Old Mar 24, 2004 | 07:22 AM
TURBO-TEG's Avatar
i run the 225/50/15 g-force (front) on the stock integra blades 15"......they work fine for me.....as for cornering......im not very big on it, so i cant really help u there....
Old Mar 24, 2004 | 07:31 AM
Rtype16's Avatar
Default Re: Quick tire size question for the best traction. (TURBO-TEG)
Hey I know that car....
Old Mar 24, 2004 | 07:53 AM
b16ahybrid's Avatar
Default Re: Quick tire size question for the best traction. (Rtype16)
thats the same tire and wheel offset i run. I have a 2.25'' drop and had to roll the fender to keep them from rubbing. If this is for a street set-up you will rub in the corners unless you have more of a gap then I do. Mine sits flush with the fender. maybe go with a little more offset if you plan to drive daily.
Old Mar 24, 2004 | 07:58 AM
Default Re: Quick tire size question for the best traction. (b16ahybrid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16ahybrid &raquo;</TD></TR><TR><TD CLASS="quote">thats the same tire and wheel offset i run. I have a 2.25'' drop and had to roll the fender to keep them from rubbing. If this is for a street set-up you will rub in the corners unless you have more of a gap then I do. Mine sits flush with the fender. maybe go with a little more offset if you plan to drive daily.</TD></TR></TABLE>
How far do yours stick out? Do you have any pics? I am worried more about them stick out to far and getting pulled over or it just looking out of place. I have coil overs so I could raise the car if need be.
Old Mar 24, 2004 | 09:45 AM
Rtype16's Avatar
Old Mar 24, 2004 | 03:54 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">
How far do yours stick out? Do you have any pics? I am worried more about them stick out to far and getting pulled over or it just looking out of place. I have coil overs so I could raise the car if need be. </TD></TR></TABLE>
I can get pics for you. They don't stick out at all they are flush with the fender. You will be fine unless you have a camber kit.
Old Mar 24, 2004 | 04:57 PM
Yeah I am running the skunk 2 camber kit and spc rear kit.
Old Mar 24, 2004 | 06:08 PM
b16ahybrid's Avatar
They you will probably run into problems. The only reason why I can run this set-up is because I don't have a camber kit so my wheels tilt in just enough at the top to clear the fender.
I had to roll the lip on the fender to get the tires to clear.
I have the neuspeed race springs which lower my car about 2.25'' closer to 2.5'' in the front. I supose if you raised you car up a little you may be able to clear the fender. Tell you what, I'll borrow a digital camera tomorrow and snap a few pics of my car from the side and an angle to so you can see how much room I have.
I'm runing 15x6.5'' rims with the 225/50/15 bfg dr.
CarterRace.com
May 17, 2009 06:25 PM
gosu08
Sep 14, 2007 05:51 AM
sumyungguy
Dec 14, 2005 02:28 PM
jdmhatch3
Aug 11, 2005 04:50 AM
93VTEChatch
Feb 27, 2003 07:40 AM
