Anyone using CPR "plug n play" OBDII>OBDI injector clips?
Like the title says, are there anyone using these clips or has had any experiences with them? I was told that they are completely plug and play and i was also told that they dont clip up all the way, and that you have to trim the harness(es) in order to get them to fit. These clips seem good for simplicity sake and cleanliness. Thanks.
HELLO,GOOD MORNIN'
Re: Anyone using CPR "plug n play" OBDII>OBDI injector clips? (lilxvtecxpwr)
got a link i would like to see them<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilxvtecxpwr »</TD></TR><TR><TD CLASS="quote">Like the title says, are there anyone using these clips or has had any experiences with them? I was told that they are completely plug and play and i was also told that they dont clip up all the way, and that you have to trim the harness(es) in order to get them to fit. These clips seem good for simplicity sake and cleanliness. Thanks. </TD></TR></TABLE>
Re: Anyone using CPR "plug n play" OBDII>OBDI injector clips? (HybridcivicLS-T)
yeah i got them sitting right here LOL.....gonna install them manana
HELLO,GOOD MORNIN'
Re: Anyone using CPR "plug n play" OBDII>OBDI injector clips? (B18Flip)
I liek those. I just may get me a pair. I cut my harness and put it back together again so amny times. I rally like those. I don't see why they would not work. You can carry a set of injectors with you. Let say you get some stupid problem where an injector is stuck open and oyu want o put stock nack in... makes it simple as hell. I like that.
well i remember awhile back when viren was selling these, someone had problems with the fitment or something. like they had to trim the harnesses. its no big problem, i just want to know.
let me know if they just plug up with no trimming b18flip.
Re: Anyone using CPR "plug n play" OBDII>OBDI injector clips? (BodyKits NW)
Where's the best/easiest place to get these clips from? I'm not too keen on faxing details through from Australia and the online store seems to be down.
Re: Anyone using CPR "plug n play" OBDII>OBDI injector clips? (Hella_JDM)
Obviously to some it may seem that way but others such as myself won't mind paying ~$30 extra to do aware with any harness mods.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lilxvtecxpwr »</TD></TR><TR><TD CLASS="quote">well i remember awhile back when viren was selling these, someone had problems with the fitment or something. like they had to trim the harnesses. its no big problem, i just want to know.
let me know if they just plug up with no trimming b18flip. </TD></TR></TABLE>
yeah i got these from viren a while ago...i had to trim the inside out abit on the obd2 side w/ a dremel. Nothing too bad just had to open it more to get it to fit. i'll take pics soon
they have two versions now they got direct plug and play and one for ford style obdII plug when ordering ask goran to get you the import version for hondas
Re: (Ej6andslow)
i think it's a good investment.....i really didn't want cut up my oem harness so i made a custom resistor/injector/obd2-1 adapter with them. Here are some pics (lmk if they dont show up, imagestation is gay sometimes)
Re: (B18Flip)
so these would work with RC injectors, with some trimming?
they look different...i dont like the idea of cutting the harness, soo... but the connectors look different to me.
Re: (pornstarSR)
yeah the little plug plugs into your oem obd2 plug, and the bigger side plugs into the aftermarket injectors. They will fit most aftermarket injectors i believe, i've tried them on RC's, Siemen Deka's and precisions (delphi) and they fit
Re: (B18Flip)
so if i buy these CPR injectors clips and RC 750cc SATURATED Injectors (from ben@importparts.com) its all plugNplay no rewiring and using resistor box???? for an OBD 2 car
Re: (SPOON_BeIgHtEeNsEe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPOON_BeIgHtEeNsEe »</TD></TR><TR><TD CLASS="quote">so if i buy these CPR injectors clips and RC 750cc SATURATED Injectors (from ben@importparts.com) its all plugNplay no rewiring and using resistor box???? for an OBD 2 car</TD></TR></TABLE>
yup
yup
Re: Anyone using CPR "plug n play" OBDII>OBDI injector clips? (b18bturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bturbo »</TD></TR><TR><TD CLASS="quote">i can get it for you let me know </TD></TR></TABLE> that's where i got mine from
Modified by B18Flip at 11:14 AM 4/2/2004
I got a set from Viren a long time ago and they are waiting to be installed on the Turbo'ed Hype R Ek9... They fit great on RC's... got mine for $50 from Viren... CLEAN, and no going to the hospital from utility knives when cutting up your stock harness for a resistor box
