need some advice on setup
Old Mar 23, 2004 | 04:31 AM
Ottoman's Avatar
Default need some advice on setup
hey guys i'm lookin to boost my
D16a9 it's mated to a JDM d15b tranny with LSD
CR is 9.1 i believe as i have the non Cat version
i got my hands on a IHI turbo from a JDM wrx and am lookin to run maybe 7-8 PSI on it
sadly the easy part is bolting.. the hard part is the management
I live in an area with no Dyno tuning acess... so it'll be all DIY
i was lookin at using a vortech rising rate FMU 12:1 and the missing link MAP Bypass
would this be enough to make it a reliable daily driver... i live in desert climate so soummer temps soar.. and it's real humid...
would i need an MSI box? like an SCI for example?
thanx
Old Mar 23, 2004 | 10:48 AM
Ottoman's Avatar
Default Re: need some advice on setup (Ottoman)
bump
Old Mar 23, 2004 | 01:16 PM
Ottoman's Avatar
common somebody must have some sort of input??
it's not like i'm asking for the proof of einstienian theorems here
Old Mar 23, 2004 | 01:42 PM
TravSi's Avatar
i think you should search first there is so many threads on this issue, you have all kinds of ecu programs, afc, stand alones, and the type you mentioned....make sure you click archive in the search screen, u will find everything you need to know....unless yur illiterate
aznboi_106
Apr 12, 2010 10:27 PM
raysjdmh22a
Mar 17, 2006 07:01 PM
jeffk182
Feb 20, 2006 06:49 AM
egturbo
Oct 6, 2004 02:01 PM
X2BOARD
Aug 11, 2003 08:18 PM
