Two Injectors in Series?
Old Mar 23, 2004 | 06:45 PM
red91sit's Avatar
Default Two Injectors in Series?
I was wondering if I add a low impedance injector in series with my stock injector and use a resistor that is 2 ohms lower (low impd. injector) than the stock resistor would this injector work just like one wired in series with the stock resistor but with out the stock injector?
It wouldbe for a nitrous application with a 440 dsm injector wired up with a jumper switch in parralel to the added injector to disable it when not on the bottle.
Old Mar 23, 2004 | 09:03 PM
dfoxengr's Avatar
Default Re: Two Injectors in Series? (red91sit)
confuzing. basically you want one more injector for more fuel? you have a dry kit i assume?
Old Mar 24, 2004 | 08:08 PM
red91sit's Avatar
Default Re: Two Injectors in Series? (hybridvteceg)
Ahh yes I do have a dry system.
My question is would hte low ohm injector work like a regular low ohm injector wired into a normal resistor box setup?
Old Mar 24, 2004 | 10:39 PM
dfoxengr's Avatar
why not hook the 5th inj. to fuel, and ground, then for the power us the nitrous switch, when you push the nitro button, it sprays extra fuel?
PS i dont get your diagram, wheres power coming from and why do you have 2 resistors in there.
bangin'gearz
May 2, 2017 05:09 PM
done
Apr 9, 2008 02:44 PM
THEUSED
Oct 31, 2005 06:36 AM
Mr.Death
Jan 30, 2005 08:23 AM
