gsr/ls block question
Old Mar 22, 2004 | 05:01 PM
typeRSXS's Avatar
Default gsr/ls block question
i currently have a 98 gsr, still learning about turbo, etc etc. i've been looking for a blown gsr block for the longest time, and no luck. my question is, if i get a ls block and build it, (sleeves, pistons, rods) would it be just the same if i had gotten a gsr block and built it as well? thanks
Old Mar 22, 2004 | 05:27 PM
DaX's Avatar
DaX
Loved
Community Favorite
Non-VTEC blocks do not have oil squirters. A built LS block can probably handle just as much HP as a built GSR block.
Old Mar 23, 2004 | 02:22 PM
typeRSXS's Avatar
if i did use a ls block, what are some downsides apposed to the gsr block. thanks
Old Mar 23, 2004 | 02:25 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: (shupaGSR)
oil squirters. that's it.
Old Mar 23, 2004 | 03:46 PM
99B16Si's Avatar
oi squirters arent even an issue with forged pistons. the main difference your gonna run into is that an ls block has a slightly weaker rod to stroke ratio (1.53:1 in an ls vs. 1.58:1 in a gsr) an ls also lacks a crank girdle which keeps the crank a little more stable at higher rpms compared to regular main caps that an ls uses
parts for an ls tend to be a bit cheaper and more available and u will get almost a half a liter more with an ls block
Old Mar 23, 2004 | 05:08 PM
typeRSXS's Avatar
thanks for the input!
my search for a c1 block continues!
Old Mar 23, 2004 | 05:27 PM
porsche997dc2's Avatar
Finding a gsr bare block is very hard. My current build up is a ls block with gsr crank, rod, and pistons. I can get ls block for a $100 all day.
Old Mar 23, 2004 | 11:41 PM
typeRSXS's Avatar
Default Re: (porsche997)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by porsche997 &raquo;</TD></TR><TR><TD CLASS="quote">Finding a gsr bare block is very hard. My current build up is a ls block with gsr crank, rod, and pistons. I can get ls block for a $100 all day.</TD></TR></TABLE>
yea i see ls blocks everywhere.
Old Mar 24, 2004 | 12:49 AM
97lstegra's Avatar
I'd just go with the LS Block. GSR crank would be nice to have though.
Old Mar 24, 2004 | 12:59 AM
DIRep972's Avatar
Smarter than you
Default Re: gsr/ls block question (shupaGSR)
why don't u build the motor you have in ur car?
Old Mar 24, 2004 | 01:43 AM
lilxvtecxpwr's Avatar
Default Re: gsr/ls block question (DIRep972)
i guess because of less down time.
Old Mar 24, 2004 | 03:54 PM
typeRSXS's Avatar
yea i didnt feel like having any down time.
fatpride111
Apr 10, 2008 06:08 AM
faSHOwidIT
Aug 2, 2006 04:40 AM
EK FLY
Jan 4, 2006 06:17 PM
blmracing
Feb 25, 2003 10:15 PM
