gsr cams
Old Mar 22, 2004 | 02:10 PM
bluesi00's Avatar
Default gsr cams
to put gsr cams in my turbo civic si do i have to use gsr cam gears, or do i use my stock cam gears??
Old Mar 22, 2004 | 02:11 PM
TeamCracka's Avatar
Default Re: gsr cams (bluesi00)
Doesnt matter, both will fit fine.
Old Mar 22, 2004 | 02:20 PM
bluesi00's Avatar
ok cool thanks. also the clearences of the valvetrain stay the same as a stock b16a2 head??
Old Mar 22, 2004 | 03:36 PM
Jared's Avatar
Default Re: (bluesi00)
valve lash will need to be adjusted but the specs stay the same
Old Mar 23, 2004 | 07:59 AM
bluesi00's Avatar
what will they be adjusted to?
Old Mar 23, 2004 | 08:27 AM
Rod.'s Avatar
I would like to know also. I am in the same boat
Old Mar 23, 2004 | 12:43 PM
bluesi00's Avatar
Default Re: (redturbocivic)
Old Mar 23, 2004 | 09:54 PM
99blusi's Avatar
I believe Si cams and GSR cams require the same clearance...not 100% on this, but I'm thinking that they do.
Old Mar 23, 2004 | 10:15 PM
bluesi00's Avatar
can anyone add to that???
Old Mar 23, 2004 | 10:32 PM
ScottEK's Avatar
You adjust the valve lash to the setting of your head, one of the reasons they will have to be adjusted is because when you are installing them you loosen the valve lash adjustments to prevent the cam from binding. Dropping in the cams and just smashing on the cam caps wouldn't be very wise.
kdohio
10
Oct 26, 2010 11:49 AM
TurboJdmEF9
May 26, 2006 02:16 PM
kndaqikEG
Jan 12, 2005 01:09 PM
