finally get her back up and running. first race on video with 500hp supra
after blowing the motor on the dyno(melted piston and cracked head) 2 weeks ago, i finally got her rebuilt and running decent. first race was setup with a buddy of mine in gainesville. we ran twice, once from 2nd where had had some bad traction issues and he jumped 3 cars on me. and once from 3rd where i can either spin or grip depending on the road(i hooked on this one)...both of us has passengers.
http://www.we-todd-did-racing....DE%3D
use the brightness adjustment in win med player to see the vids better.
Modified by 99B16Si at 8:24 PM 3/21/2004
Re: finally get her back up and running. first race on video with 500hp supra (99B16Si)
What kinda horsepower did you end up with? Still waiting for the videos to download.
In all reality, you may as well have just made them into audio files.
i dont know how much power it has now. its probably around 380whp/295wtq at 18psi. it needs a bigger turbo to flow more hp up top. i pulled a shitload of timing out to be safe and added a little more fuel. its running right around 11.0:1 a/f ratio and 13.6 degrees of timing at 18psi.
that supra ran a 12.6@120mph before he put the sticky 295's in the back
Re: (Jdm93civic)
setup is:
B18a sleeved by GE to 84mm
eagle rods
cp 9:1 pistons
b16 head
skunk2 valvetrain(thank god, i wasnt used to the power and i dont have a rev limit set so i accidently revved to 9300rpm in 4th )
stock gsr tranny
stock axles
aem ems
t3/t4e 60-1 .63ar stage 3
880cc injectors
revhard manifold
skunk2 intake mani
gsr cams
etc etc etc
eagle rods
cp 9:1 pistons
b16 head
stock gsr tranny
stock axles
aem ems
880cc injectors
revhard manifold
skunk2 intake mani
gsr cams
etc etc etc
Re: (99B16Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99B16Si »</TD></TR><TR><TD CLASS="quote">i pulled a shitload of timing out to be safe and added a little more fuel. its running right around 11.0:1 a/f ratio and 13.6 degrees of timing at 18psi.</TD></TR></TABLE>
Isn't it bad to pull too much timing? Especially with a bigger bore. Just wondering
too little timing can create higher egts but its better than having too much timing and detonating. my motor blew from god aweful detonation at 17 degrees and 20psi on pump gas. i dont wanna take anymore chances
yes i know from the extra heat, but like i said 13.6 is safer than 17...generally speaking. obviously every motor is different.
Mase...i calibrated everything on the aem this time and triple checked everything, especially timing, for accuracy. itll be back on the dyno within the next couple days to double check the a/f. everything should be the same tho. im still trying to get those calibrations over to you but its kinda hard without a laptop
Smarter than you
Mase do you really think he is running enough retard to cause detonation? Its only a few degrees back from the 9:1, 18psi, pump gas motors I have seen.
Re: finally get her back up and running. first race on video with 500hp supra (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 »</TD></TR><TR><TD CLASS="quote">Mase do you really think he is running enough retard to cause detonation? Its only a few degrees back from the 9:1, 18psi, pump gas motors I have seen. </TD></TR></TABLE>
nah, as long as his timing is sync'd w/ the aem.... ive seen some cars way off, some retarded, some advanced.....
he should be just fine w/ that total timing
btw, you should have told me you were in gainesville, u could have stopped by and said whats up
Location: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
"i dont think hes got it, i dont think hes got it..ah man hes got it"..LOLOL
i love to see vids like this...almost remimds me of the one with the blue hatchy.....
itsukivr6
11-09-2011 07:12 AM
GRS Motorsports
10-06-2011 03:30 PM
MattD@Stoptech
04-09-2003 07:31 PM
