Making backdoor on intercooler
Old Mar 22, 2004 | 05:38 PM
sneakypete's Avatar
Default Making backdoor on intercooler
I want to make a backdoor on my intercooler for I can fit the full-race traction bars. My question is what's the best way to clean out the intercooler after making the hole? Will blowing the intercooler out with air get all the metal shavings out from inside the intercooler? Thanks
Old Mar 22, 2004 | 05:40 PM
Nid Styles's Avatar
Default Re: Making backdoor on intercooler (sneakypete)
WHAT?!
Old Mar 22, 2004 | 05:42 PM
RenoRacing's Avatar
Default Re: Making backdoor on intercooler (nd_styles)
yeah, or even some water wouldn't hurt it, just let it dry for a day or two before you throw it back on.
Old Mar 22, 2004 | 05:43 PM
DXK Eg's Avatar
i would use a blow gun and spary it from the other side, meaning not the side you were cutting on..or a water hose?
Old Mar 22, 2004 | 06:31 PM
slim9300's Avatar
I have DTR Traction Bars and they are going to fit on my turboed H22 Teg. How big are the Full Race Traction bars?
Old Mar 22, 2004 | 06:51 PM
Bailhatch's Avatar
Default Re: Making backdoor on intercooler (slim9300)
put thick grease around the cut before you make it. that will trap most of cuttings. Then wipe it from the inside out with a small clean cloth. then maybe flush it put w/ water. make sure you clean all the grease off or you won't be able to weld it. use a hole saw too.
Old Mar 22, 2004 | 11:07 PM
sneakypete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slim9300 &raquo;</TD></TR><TR><TD CLASS="quote">I have DTR Traction Bars and they are going to fit on my turboed H22 Teg. How big are the Full Race Traction bars?</TD></TR></TABLE>
My IC piping is right in the way of where the mount goes for the traction bars. The mount goes where the toe hook is. I can mount the crossmember with no problem but where the tie rods mount to the crossmember, the IC piping is right in the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">put thick grease around the cut before you make it. that will trap most of cuttings. Then wipe it from the inside out with a small clean cloth. then maybe flush it put w/ water. make sure you clean all the grease off or you won't be able to weld it. use a hole saw too.</TD></TR></TABLE>
Thanks for the info.
jdm2teg
Oct 7, 2005 07:12 PM
Koyoloeor
May 16, 2005 05:39 AM
superstud
Feb 22, 2004 01:03 PM
Nextelbuddy
Aug 26, 2003 08:43 AM
