safe to buy used tial wastegate?
I currently have a deltagate..and i found a tial 38mm for $160 while the brand new ones cost around $210...is it safe to buy a used one? how can i tell if it's still in good condition? or should i just play it safe and spend the xtra $60?
Re: safe to buy used tial wastegate? (teameracer3)
Wastegates are pretty hard to mess up. I have never really heard of anyone breaking one. They wear out, but I suspect it takes quite a bit of time for this to happen, as I have seen many with high mileage on them. As with anything though you take that risk that the last guy was an idiot. I would go with the used one personally.
Jake D.
Jake D.
Re: safe to buy used tial wastegate? (TeamCracka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamCracka »</TD></TR><TR><TD CLASS="quote">You also get the benifit of having the spring allready be broken in!</TD></TR></TABLE>
yep, this is very true. also its important to properly break in the ball bearings as well.
Re: safe to buy used tial wastegate? (Mase)
alrite thanks guys!
just in case i decide to buy a new one anyway...how do I properly break in a wastegate...because my motor is currently being built...so when it's done...i'm going to have to break it in anyway...so having to break in the wastegate is not a big deal to me...i'd rather spend a lil more then not knowing what the last owner did to it ya knoe...but yea...how do you properly break in a wastegate?
Theres no way to "break-in" a wastegate except for hitting the PSI the internal spring (or a manual or electronic boost controller) is set for.
After a bunch of high-heat cycles and opening/closing's of the diaphram/spring everything will loosen up and settle and you'll be good.
The only con to running a non-broken in wg is that the spring is initially stiffer, so say if you have a 7.5 lb spring, it might allow 7.5-8.5 of boost before it startes bleeding exhaust.
I bought one at a pretty good price with ony one missing air fitting and no hardwear
Modified by usdmcivic94 at 10:52 PM 3/6/2005
11psiTurboSI
05-20-2004 05:12 PM
B18Flip
04-15-2003 06:08 PM
