vti and vto in vafc.
Old Mar 21, 2004 | 12:44 AM
egturbo's Avatar
Default vti and vto in vafc.
sup guys. i was wondering whats vti and vto on vafc? well when my vtec engages vto says its on. but the vti is off. just wondering. my oil pressure valve isnt wired up yet can it be that?
Old Mar 21, 2004 | 06:00 AM
IN VTEC's Avatar
Default Re: vti and vto in vafc. (egturbo)
vti is when the ECU sends the signal to activate the solenoid. This signal is intercepted by the VAFC. The solenoid doesn't even get to see this signal with the VAFC in place.
vto is when the VAFC sends the signal to activate the solenoid.
I believe the only time the vto = ON and vti = OFF, is if the VTEC crossover point on the VAFC is less than whatever crossover rpm the ECU you're running is sending out. Maybe you're running a JRSC.
Old Mar 21, 2004 | 06:08 AM
b_jamin's Avatar
Default Re: vti and vto in vafc. (IN VTEC)
took the words from my mouth
Old Mar 21, 2004 | 12:15 PM
egturbo's Avatar
Default Re: vti and vto in vafc. (b_jamin)
should both be on? cuz only my vto turns on. its a stock y8 tia
Old Mar 21, 2004 | 01:25 PM
IN VTEC's Avatar
I don't know know what you have it set at on the VAFC. Compare the stock crossover rpm and the rpm set on the VAFC. You can figure the rest out.
twiztid00002
Jan 14, 2008 09:31 PM
wicked_b16eg
Dec 30, 2007 11:10 AM
EK_BackHatch
12
Mar 4, 2004 02:05 AM
IgniteTeg
Apr 30, 2002 09:19 PM
HX_Guy
Jan 20, 2002 05:40 PM
