adjusting ignition timing?
Old Mar 20, 2004 | 11:55 PM
VspecSiR's Avatar
Default adjusting ignition timing?
adjusting ignition timing on a b16a (00' civic Si) means moving the distributer to the rear or to the front of the car? A friend of mine told me it's moving it to the front of the car. I just want to know to be sure? Timing should be 1 degree per pound of boost correct?
Old Mar 20, 2004 | 11:58 PM
GForceInteg's Avatar
Default Re: adjusting ignition timing? (VspecSiR)
I believe the amout of retard is determined by how much boost your going to run. I got the msd 6btm which comes with boost retard so it retards as you boost. But if i could add to this question with:
Could to much retard hurt your motor, i know to much advance obviously can but what about retard?
Old Mar 21, 2004 | 12:04 AM
VspecSiR's Avatar
Default Re: adjusting ignition timing? (GForceInteg)
I'm actually only running the stock boost with the greddy kit which is what something like 5.5psi or so. I'm also intercooled. I just want to retard the timing a bit so I can be extra safe, even at this low boost level.
i believe too much retard can rob you of some power, but gives you less chance of detonation.
Old Mar 21, 2004 | 04:40 AM
b18cls1's Avatar
retarding base timing will rob off boost power but will give you the extra comfort in boost but with 5-6psi not to much to worryabout its up to you
Old Mar 21, 2004 | 08:53 AM
VspecSiR's Avatar
Default Re: adjusting ignition timing? (b18cls1)
so anyone know which way is retard? towards the rear of the car or towards the front?
Old Mar 21, 2004 | 09:37 AM
b16ahybrid's Avatar
At that boost setting I would run stock timing. If you hear detonation which i doubt you will if your using 92 octane then retard it about 2 degree's at most.
Also you shouldn't adjust timing without a timing light, get one of those and you won't need to ask this question.
Old Mar 21, 2004 | 10:45 AM
boosted_dc2's Avatar
Default Re: adjusting ignition timing? (b16ahybrid)
to retard it you turn it towards the front of the car (clockwise).
Landon
Old Mar 21, 2004 | 10:53 AM
raene's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GForceInteg &raquo;</TD></TR><TR><TD CLASS="quote">Could to much retard hurt your motor, i know to much advance obviously can but what about retard?</TD></TR></TABLE>
Yes, it can, though the amount of retard to cause piston damage is huge. Typically retard just raises EGT, which is a bad thing.
Old Mar 23, 2004 | 08:26 PM
VspecSiR's Avatar
Default Re: adjusting ignition timing? (raene)
is it really a bad thing? I keep hearing people say to retard your timing a bit in relation to the amount of boost your running to be safer???
Old Mar 23, 2004 | 08:30 PM
b16ahybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VspecSiR &raquo;</TD></TR><TR><TD CLASS="quote">is it really a bad thing? I keep hearing people say to retard your timing a bit in relation to the amount of boost your running to be safer???</TD></TR></TABLE>
Thats if you have a device to do it in proportion. Like a msd btm, or ems.
I've found on my b16, stock timing is ok up to about 6psi, above that you should retard timing about 2 degree's (up to about 10psi). I ran my b16 @ 9.5psi at stock timing. I used my crane boost retard to retard my timing about .3 degree per psi.
Old Mar 23, 2004 | 08:34 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by raene &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, it can, though the amount of retard to cause piston damage is huge. Typically retard just raises EGT, which is a bad thing. </TD></TR></TABLE>
Wow i know this is going to hurt but, what is EGT.
Old Mar 23, 2004 | 08:46 PM
b16ahybrid's Avatar
take a deep breath....ok
Exhaust Gas Temp.
Why would it hurt? It was a simple painless question.
Old Mar 24, 2004 | 07:50 AM
raene's Avatar
Imagine your exhaust valves glowing... melting...
The exhaust valves will cook far earlier than the intake valves because they never get a cool charge of intake air and fuel going past them. They only get heat, and heat, and more heat.
Old Apr 30, 2004 | 10:39 PM
1SlowSi's Avatar
Arent you suppsed to advance your ignition timing when you increase the boost? i see people with 24* when 15psi and more.
Old Apr 30, 2004 | 10:47 PM
MaxSterling's Avatar
Default Re: adjusting ignition timing? (1SlowSi)
they are talking bout static timing,
93civciv
Dec 4, 2007 05:23 PM
BEV@GSCMotorsports
May 14, 2004 10:00 AM
pipes
Feb 20, 2004 09:19 AM
Licensed2Spool
Apr 9, 2003 06:22 AM
808eg6
Jun 24, 2002 07:52 AM
