wtf is going on with my compression?????
Old Mar 23, 2004 | 12:41 PM
B1Boosted's Avatar
From: from a lil town called none ya gatdamn business, usa
Default wtf is going on with my compression?????
ok i recently swapped the head on my ls turbo with a b16 head and after running the car on 15psi when i didnt realize that it was creeping that high i checked the compression and cylinder #4 was 145 at first and cylinder #3 was about 140 then i checked the compression again after running the car and #4 was like 130 and #3 was like 138..... then i finally got my boost creep prob down to 10psi and was gonna see if the compression was goin to drop anymore before i pulled it apart and after running it again w/ race gas (110 oct) i checked the compression and #4 was like 140 and #3 was like 130....so why is my compression varying up and down....valves bad????/valves need adjusting????? rings???? was told to adjust valves 1st and go from there... what do you think
Old Mar 23, 2004 | 01:15 PM
Stewie's Avatar
Default Re: wtf is going on with my compression????? (B1Boosted)
Did the temp of the engine vary? When I let my engine cool down on my truck, my leakdown test varies a whole lot.
Exhaust valves seal a lot better when they're hot.
Old Mar 23, 2004 | 05:26 PM
B1Boosted's Avatar
Default Re: wtf is going on with my compression????? (Mac8008)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mac8008 &raquo;</TD></TR><TR><TD CLASS="quote">Did the temp of the engine vary? When I let my engine cool down on my truck, my leakdown test varies a whole lot.
Exhaust valves seal a lot better when they're hot.</TD></TR></TABLE>all the times that i did the comp tests the motor was hot... but do you still think its a valve seat prob or a burnt valve...thanks for the info
Old Mar 24, 2004 | 10:38 PM
B1Boosted's Avatar
well i guess im jus gonna run the **** out of it till it blows so **** it....thanks
Old Mar 24, 2004 | 10:41 PM
5thgencivic's Avatar
You hold the throttle wide open for all compression tests? Also, did you crank until the needle stopped rising for each cylinder?
Old Mar 24, 2004 | 10:43 PM
B_1_8_hatch's Avatar
those numbers seem low anyway.
my ls motor has compression numbers at 180 all the way across.
Old Mar 24, 2004 | 10:44 PM
B1Boosted's Avatar
Default Re: wtf is going on with my compression????? (5thgencivic)
thats another thing i....did not hold it full throttle..in which i was told to do so today..but i did crank until the needle completely stoped rising in each cylinder... im tryin to get every bit of faith that i can hahaha.... thanks man
Driver_c
Aug 15, 2015 03:31 PM
Z32Z06
Honda S2000
Feb 8, 2006 04:59 PM
boosted_lude
Jan 27, 2006 09:31 AM
zoom545
Nov 22, 2005 09:04 AM
CNSK
Apr 10, 2005 08:54 AM
